Honda S2000 Honda S2000
what plugs to use with nitrous?
Old Feb 17, 2006 | 08:25 PM
nvrsatisfied's Avatar
Default what plugs to use with nitrous?
I have put a 50 shot wet on my 2002 S2000 want a colder plug than factory ngk's anyone know of any i have a denso # but dont know if its right because i cant find them anywhere the # is either IK24 or 1K24 need help not going to use nitrous till i have the plugs i need.
Old Feb 17, 2006 | 09:52 PM
JEFFOS69's Avatar
Default Re: what plugs to use with nitrous? (nvrsatisfied)
You will want to go about 2 stages colder. The part number you have is incorrect. NGK uses 2 types of part numbers - for example when I had my nitrous integra I used NGK BKR7e but the part number was also under NGK-6097. You need to find the 4 digit part number NGK uses.
Once you find that search NGK-(4 digits) at summit racing online and youll find it.
Anyways for example this is how my BKR7e's showed up on summit (You need different plugs but this will be used for an example)
http://store.summitracing.com/...00395
Hope this helps a bit.
Old Feb 17, 2006 | 09:58 PM
JEFFOS69's Avatar
Default Re: what plugs to use with nitrous? (JEFFOS69)
Did some quick research for you
The plugs you may be looking for are DENSO IK24, or DENSO IK22
Also may be used are NGK 3330 and NGK 6097
The denso will be preferred as they are iridium and will last longer but are like 6x the price. The NGK's you will want to change about every oil change also as well make sure you check the plugs after spraying at first and every once in awhile to make sure everything is ok.
Old Feb 17, 2006 | 10:06 PM
one of my friends told me that was the number for the denso plugs
thanks for the info helped alot
lude98SH
Jun 24, 2007 02:39 PM
shhh151
Dec 15, 2006 03:51 PM
97grnrs
Jan 2, 2006 04:43 PM
tegon-gsr
Jun 4, 2004 11:44 AM
