Skunk 2 Manifold
I have been hearing 2 sides, but if i put it on then it will kill my low end right??? but y would someone wanna do this when the GSR's peak at 7600 or so. Im just curious, so if im wrong someone please correct me, but im saying if GSR's have real good top end then why would u wanna kill your low end??? Im asking this question because i was interested in buying the manifold but i dunno know... TIA
your low end is killed with the skunk2 if your running the stock cams & ecu (kills the IAB)
otherwise, you will gain everywere
[Modified by hybrider93, 2:57 PM 3/27/2002]
check my signature i have no bottom end power what so ever, i need pistons bad, you cant touch me with my top end but my bottom is not there. I lost it when i put skunk 2 stage 2 cams and intake manifold
well one guy on here just said he made gains with a ITR ECU and the Skunk 2 mani and the other guy says he has cams and everything else and his low end sucks, which one is true???
Without cams i personally felt the mod was worthless
First off the labor is a bitch
Second the gsr vtec crossover is to low and ITR Ecu crossover is too high
Third you will need a vtec controller to change the x-over to about 4800-5000
I raced my fathers GSR and no pulls anywhere throughout power band it was pretty close til 3rd when i (ever so slightly ) started to pull to half a car length
His GSR was stock mine had VAFC, S2IM, Icebox
ok, so the people who has these things, ECU, cams, & manifold how much was installation?? and is it really worh it 2 get the manifold??
[Modified by TeamTooQuick, 2:09 AM 3/28/2002]
[Modified by TeamTooQuick, 2:10 AM 3/28/2002]
is this bolt on worth it???
I've done a lot of these motors and the difference in gsr ecu/gsr manifold to single stage ecu/skunk2/type r manifold is about 2-3/10ths in the 1/4 mile and a whole 1.5 cars in a street race !!!
take my word for it ...
Greg
So when i get the Skunk 2 mani, ill have 2 get new cams like skunk 2 cams, ITR ECU??? cam gears, and would i need new retainers and stuff, what all am i going 2 have 2 buy??? whoever has done this before just list what u put on when u got the Skunk 2 mani. TIA
Hey same here..i am planng on this SKUNK2 intake manifold setup as well and would like to know the detailed parts that everyone else got when they installed their manifold, before i go out and start buying anything
Skunk2 Intake
Skunk2 Cams - Level 2
Skunk2 Springs and Retainers (Keeping stock GSR Valves)
Skunk2 Cam Gears
I already have a VFAC but I will also be adding a Hondata Level 2 (Got a friend with level 4 so he will be burning me a chip after I get some dyno time). I plan on yanking the head off to do this operation to make the intake and spring upgrade easy. While I'm going that I will be also upgrading the head studs (ARP) and replacing all the gasgets. I was going to upgrade the pistons to ITR but I decided to hold off on that. But then again that depends on what I see when I pull the head off.
actually no other modifications is required when upgrading the manifold, just that other mods such as bigger camshafts, upgraded valvetrain, adj cam gears, better flowing and designed header all complement the intake manifold design, i.e. when the japanese aftermarket companies make products like headers or camshafts, companiels like Spoon, Toda, Cusco, Mugen, etc. they all try it with the b16a in mind, the manifold that comes with the b16a is similar yet smaller to the ITR or skunk2 intake. There is a reason for this.
I have a couple of used skunk2 intake manifolds for sale also along with valvetrain upgrades, etc.
... had to put the plug in there !!!
Greg
... had to put the plug in there !!!Greg
yeah, its worth buying. and stinky tofu i feel that my bottom sux for what i have done not impressed, but i am stoked with my top end, just doenst start till 5800 rpm.
I have a brand new S2 IM here with me, and I'm going to install it in a week or two. I only have I/H/E and stock ECU. Will it hurt my times? Will it give me better times? I know I'll lose low end, but gain top end. I dont mind sacrificing my low end to gain top end, since Top end is what really matters in a race.
Let me know what you think. Thanks!
No it wont hurt, but u might not notice that much of a gain but its definitley going too sound better. If you get a throttle body too then you will notice a nice difference, atleast I did.
how much are you selling those used skunk2 manifolds for i'm interested in getting one...e-mail me with a price...e-mail me at deparsons@cinci.rr.com ...
later,
Dan
later,
Dan
TheCrimsonGhost666
Jun 6, 2010 08:42 AM
VTECcnIT
Apr 21, 2006 08:58 AM
VTECcnIT
Mar 28, 2006 04:37 PM
