modded EJ1 side skirts
im about to pick up a 95' civic DX coupe and its all kitted. i plan to remove the kit and add stock front and rear bumpers but have herd you can fit EK side skirts on a "eg" coupe. now is this correct and can somebody post a picture if it is? i want to do this to be a little bit different from the stock coupe skirts. and also whats a clean all black polyurathane front lip? TIA-
I put ek skirts on my hatch back then.
You'll have to drill a couple new holes and file them to a square to allign the mounting clips.
Then you'll have to cut the skirts down about an inch.
Can't remember if you have to cut for the coupe though.
Took me about an hour with breaks in between cause i broke like 3 of my dremel bits.
Bthasht
Mar 13, 2009 07:51 PM
StRoKeD-B16bEj2
Jul 31, 2006 07:22 PM
i found a DIY on it
