how do you remove tint??
Old Mar 27, 2002 | 01:43 PM
xJ.SLOTHx's Avatar
Default how do you remove tint??
whats the best way to remove tint off the windows of a car? thanks.
Old Mar 27, 2002 | 02:16 PM
GSR2001's Avatar
Default Re: how do you remove tint?? (ian)
Amonia will take it off easy!
Old Mar 27, 2002 | 02:26 PM
garados's Avatar
Default Re: how do you remove tint?? (GSR2001)
pure amonia? or glass cleaner with amonia?
Old Mar 27, 2002 | 06:52 PM
quis23's Avatar
amonia and vinegar will do the trick--spray it on and let it sit for a while;get a razor and get to scrapin'!
Old Mar 27, 2002 | 07:04 PM
aNaRcHyiNmYeK's Avatar
i use to worka sunn ezz tinting..........follow thes steps and ull have ur tint off in 45 min......with no razor blade involved...and barely any labor......ok .....get to trash bags.....preferably the brown or black one's.....and a spray bottle with water........cut or tear the trash bags apart from it original form....so it can form to the window.....dont do all at the same time......spray the window down with water......paste the trash bag to the window it will suck up to the window..make sure its on there good.....finish one side of the car....and park it so the sun is beaming down on the side that u did...let it sit for 30 to 45 min..depending on how hott it is...the hotter the faster....use good judgement on when to take it off....now when ur ready to take it offf ....it will come off smooth like unpeeling a new sticker....if it doesnt come off smoothly...let it sit longer....and then proceed...with the back of the car ..then the other side.....this is how the pro's do it
Old Mar 27, 2002 | 07:11 PM
FifthGearOnline's Avatar
Default Re: how do you remove tint?? (aNaRcHyiNmYeK)
wow nice tip!!! ill tell a friend of mine that!
Old Mar 27, 2002 | 07:49 PM
matthewk's Avatar
Default Re: how do you remove tint?? (FifthGearOnline)
If you have any residue left over, hot watter and dish soap with some paper towles will take it right off.
Old Mar 27, 2002 | 08:07 PM
garados's Avatar
How about the rear window, you know the defogger lines. Is there anything to worry about there?
Old Mar 28, 2002 | 12:16 PM
Denny317's Avatar
Default Re: how do you remove tint?? (garados)
don't worry about the defogger lines. They won't come off when you take off the tint.
Old Mar 28, 2002 | 03:45 PM
Dr.Kimball's Avatar
pay sombody else to take it off for you.
Old Mar 28, 2002 | 07:23 PM
nah the de fogger is no prob..
Old Mar 28, 2002 | 08:43 PM
dc24me's Avatar
Most window tinters can't gurantee that the all the defrost lines will remain intact if they tint gets removed. I have been told the best thing to do is to HOPE that someone throws a brick through your rear window.
[Modified by dc24me, 12:44 AM 3/29/2002]
Old Mar 29, 2002 | 07:00 AM
SCsol's Avatar
Default Re: how do you remove tint?? (dc24me)
acura brake cleaner works GREAT spray it on the glue and you can wipe it right off its also for eletrics so it wont fu(k up the defrost lines!!
accord99power
Dec 12, 2008 08:35 AM
streetracerof06
Nov 30, 2005 07:53 AM
youngwon22
Sep 6, 2003 07:30 PM
civicracer99
Audio / Security / Video
Aug 26, 2003 03:11 PM
gokuson
Jun 21, 2002 01:24 PM
