More Main Relay CRAPPPPPP
Old Feb 17, 2006 | 05:19 PM
CoolRedXylophone's Avatar
Default More Main Relay CRAPPPPPP
ok, so yesturday i install a brand new relay to try to get my car running, no dice. it clicked once each time i tried to start the car and once each time i stopped. ive been reading a lot of stuff about how bad grounds can cause this, seems like a lot of people are having issues with this right now. today i go back to work on the car and check the grounds but then the main relay wasnt clicking at all.
QUESTION---if the main relay isnt clicking at all is it blown? or could an ungrounded wire be at fault???
Old Feb 17, 2006 | 05:46 PM
Default Re: More Main Relay CRAPPPPPP (CoolRedXylophone)
i promise after this no more freaking main relay questions
Old Feb 17, 2006 | 10:15 PM
juice91si's Avatar
an ungrounded wire could be the cause.
i have been having crazy issues too with my car, just today i finished making my own ground wires with thick *** amp wire, and now its so much better, no problems yet. its amazing to see how much **** bad grounds can cause, and how much they can do, when brand new and proper
i highly suggest doing your grounds.
Old Feb 18, 2006 | 03:17 AM
B16aSir2's Avatar
Default Re: More Main Relay CRAPPPPPP (juice91si)
Fixed your starting problem eh juice91si? I told you those damn grounds were the problem Weird ****, will drive you nutz. I installed a new fuel pump before I figured that out
Old Feb 18, 2006 | 03:28 AM
Default Re: More Main Relay CRAPPPPPP (B16aSir2)
yeah ive been working on this forever. i was about to replace the fuel pump as well. the car has been sitting outside only in a carport for a few years so maybe the elements have cause the grounds to go bad. h-t needs a main relay faq or something
thanks guys
pyroom
12
Apr 6, 2025 10:42 AM
boarding2008
Jun 2, 2022 01:08 PM
Civic Racer X 7
10
May 11, 2016 01:35 PM
poundedhatchcrap
19
Jun 22, 2005 05:53 PM
