Calling all d15 vtec guys.
im getting a d15 vtec pretty soon from h motors and i and going to the typical t-belt water pump blah blah blah and i was wondering what car i sould i get the parts for. like should i get them for a z6, y8 or what.
also im going to order the rywire harness
and i was talking to a friend that knows pretty much about swaps and he said that if i use the p08 ecu it will throw a EGT code, is this true and if so is there anything i can do to get around it short of pulling the bulb.
get a si tranny and the clutch/flywheel for that tranny. i ran a p28 with a custom chip, 4 wire o2, and obd1 conversion. the head is a z6 so plugs, wires, valves, valve springs, retainters are going to be from the 92-95 civic ex ( d16z6 ). the bottom end is "basicly" from the 92-95 vx model but the internals are different.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by beyondspecs_jamar »</TD></TR><TR><TD CLASS="quote">get a si tranny and the clutch/flywheel for that tranny. i ran a p28 with a custom chip, 4 wire o2, and obd1 conversion. the head is a z6 so plugs, wires, valves, valve springs, retainters are going to be from the 92-95 civic ex ( d16z6 ). the bottom end is "basicly" from the 92-95 vx model but the internals are different.</TD></TR></TABLE>
thanks, i just recieved a p08 so i won't be running the p28, im trying to do this swap with basically my tax return check so i won't be going crazy with it. my can is an si so i won't have to buy an si tranny. so basically in hearing get every thing for a 92-95 ex? any one else?
For a D15B VTEC, the proper timing belt and water pump are for a '92-95 VX.
http://www.d-series.org/forums...32597
http://www.d-series.org/forums...17840
TeG cRaZy
Jul 14, 2012 10:32 PM
Veil_Side_
Mar 28, 2002 02:48 PM
