Pop's got some new shoes...
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by cwood1388 »</TD></TR><TR><TD CLASS="quote">nice. bump up for my wheels son!</TD></TR></TABLE>
You gottem' too? Post 'em up!!!
What size/offset are you running? The rear looks to be too small. Also, GT-C normally uses different type of lugnuts which goes into the wheel. I guess the way you are doing works as well(extending the studs).
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by twenty20hindsight »</TD></TR><TR><TD CLASS="quote">Is that your real license plate or did you photoshop it?</TD></TR></TABLE>
Uhh...photoshopped...yeah photoshopped.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by djskyy »</TD></TR><TR><TD CLASS="quote">looks nice.....although, the rears are little bit too small....could use a fatter lip </TD></TR></TABLE>
Well of course but for the price they were I took 'em.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ak »</TD></TR><TR><TD CLASS="quote">...GT-C normally uses different type of lugnuts which goes into the wheel. I guess the way you are doing works as well(extending the studs).</TD></TR></TABLE>
According to Mark at DaliRacing you should lengthen the studs reguardless on an NSX. He uses Corvette studs which have the same 12x1.5 thread depth but are longer.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by negtegra. »</TD></TR><TR><TD CLASS="quote">you should lengthen the studs reguardless on an NSX. He uses Corvette studs which have the same 12x1.5 thread depth but are longer. </TD></TR></TABLE>
This is not correct. If your wheels are sized correctly and you are not running any spacers, then you do not need longer studs. I think you are supposed to get 6.5 turns on your lugnuts or more.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ak »</TD></TR><TR><TD CLASS="quote">This is not correct. If your wheels are sized correctly and you are not running any spacers, then you do not need longer studs. I think you are supposed to get 6.5 turns on your lugnuts or more.</TD></TR></TABLE>
M'eh, I ain't gonna change it now... Why do you want to find the only negative thing about my shoes?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by negtegra. »</TD></TR><TR><TD CLASS="quote">M'eh, I ain't gonna change it now... Why do you want to find the only negative thing about my shoes?</TD></TR></TABLE>
because i'm a hata yO.
Well, they do show just how much you need to paint your calipers.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Ponyboy »</TD></TR><TR><TD CLASS="quote">
Thats the first thing I noticed when I changed my wheels. I can get all 4 powder coated for $75 but it would require me to disassemble them. I'm lazy
haven't done it yet.
What is the purpose of extending the bolts if you don't use the length? Does the 1/2" that sticks out magically provide improved steering
Looks dumb if you ask me.
</TD></TR></TABLE>Thats the first thing I noticed when I changed my wheels. I can get all 4 powder coated for $75 but it would require me to disassemble them. I'm lazy
haven't done it yet.What is the purpose of extending the bolts if you don't use the length? Does the 1/2" that sticks out magically provide improved steering
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by nsxxtreme »</TD></TR><TR><TD CLASS="quote">Thats the first thing I noticed when I changed my wheels. I can get all 4 powder coated for $75 but it would require me to disassemble them. I'm lazy
...</TD></TR></TABLE>
No doesn't help steering, obviously...
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by nsxxtreme »</TD></TR><TR><TD CLASS="quote">...Looks dumb if you ask me.</TD></TR></TABLE>
Cool, not all comments are gonna be positive on a World Wide message board.
...</TD></TR></TABLE>No doesn't help steering, obviously...
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by negtegra. »</TD></TR><TR><TD CLASS="quote">Cool, not all comments are gonna be positive on a World Wide message board.
Wheels look good though
</TD></TR></TABLE>Wheels look good though
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by nsxxtreme »</TD></TR><TR><TD CLASS="quote">Wheels look good though
Thanks...too bad the rest of H-T isn't as courteous as the NSX board.
</TD></TR></TABLE>Thanks...too bad the rest of H-T isn't as courteous as the NSX board.
You are all useless.
Do it yourself you pansy.
Looks dumb if you ask me.</TD></TR></TABLE>You are all useless.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Knightsport »</TD></TR><TR><TD CLASS="quote">
Do what myself? Powder coat? I couldn't even if I wanted to. I do all the repairs to my cars
Just got done changing head gasket and rod bearings in my Accord.
Since I dont drive the NSX much it's not on my high priority list. I need to do the timing belt and water pump on the NSX, probably wont get around to that until this summer.
The dark grey looks good. I have a set of racing hart M5's on mine. I wish they had a darker grey.
</TD></TR></TABLE>Do what myself? Powder coat? I couldn't even if I wanted to. I do all the repairs to my cars
Just got done changing head gasket and rod bearings in my Accord.Since I dont drive the NSX much it's not on my high priority list. I need to do the timing belt and water pump on the NSX, probably wont get around to that until this summer.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by nsxxtreme »</TD></TR><TR><TD CLASS="quote">I wish they had a darker grey.</TD></TR></TABLE>
Powdercoat those too, foolio!
I did! but I went with the same color they came with. If I was to do it again I would go with a darker grey. Live and learn I guess.
</TD></TR></TABLE>I did! but I went with the same color they came with. If I was to do it again I would go with a darker grey. Live and learn I guess.
