Mugen shifter bushings work with the FLP shifter?
Old Feb 17, 2006 | 03:31 PM
white rocket's Avatar
Default Will Mugen shifter bushings work with the FLP shifter?
I don't see why not but I thought I'd ask. I've seen them on the C's shifter but good luck getting one of those.
Anyone see any problem using them together?
Old Feb 17, 2006 | 05:28 PM
Kengs's Avatar
Default Re: Will Mugen shifter bushings work with the FLP shifter? (white rocket)
The Mugen bushings are same dimensions as OEM (just harder), so I don't see why you would have a problem
Old Feb 17, 2006 | 07:00 PM
Default Re: Will Mugen shifter bushings work with the FLP shifter? (Kengs)
I figured as much. Thank you . Already inquired with Ausmith for an order
JjuuN R's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Kengs &raquo;</TD></TR><TR><TD CLASS="quote">The Mugen bushings are same dimensions as OEM (just harder), so I don't see why you would have a problem </TD></TR></TABLE>
heh
jdmeg9
Honda Civic (2006 - 2015)
Jan 21, 2010 08:12 PM
Andrew Marquis
Jul 5, 2009 07:18 PM
realis9
Jan 19, 2006 05:30 AM
JDMluvR
Feb 24, 2004 09:46 AM
