new Comp 4 rule
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 2008cc »</TD></TR><TR><TD CLASS="quote">vw's no weight limit
fwd or rwd?
</TD></TR></TABLE>fwd or rwd?
• MINIMUM WEIGHTS: Class minimum weight is 2100lbs.
B–Series motors – 2100lbs
H-Series motors – 2150lbs
K-Series motors – 2200lbs
Individual Throttle Bodies – Weight penalties
B/D-Series Motors – add 0
H-Series Motors – add 50lbs
K-Series Motors – add 75lbs
Vented aftermarket hoods are allowed, but no custom hoods or ram air set ups on K-Series cars allowed.
So the min weight for all other cars with ITB'S that arent honda's is 2100 ?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by paul vang »</TD></TR><TR><TD CLASS="quote">so a little rabbit that makes 200-250whp and weighs damn near 1600lbs will own if he hooks up
these numbers are being pulled from out of my *** so don't hate on me okay...
Class minimum is 2100 lb for all cars
then plus for H, K and ITBs on H ,K
All other cars with ITBs as rules will be 2100 lb
</TD></TR></TABLE>Class minimum is 2100 lb for all cars
dang so no CRX w/K-series in this class huh. jus wondering.
Wow, interesting ruling.
Steve
Steve
Guest
Posts: n/a
except it won't make that power
i haven't seen many vr6's over 200whp..
</TD></TR></TABLE>except it won't make that power
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by PhoenixTurboJesse »</TD></TR><TR><TD CLASS="quote">
i haven't seen many vr6's over 200whp..</TD></TR></TABLE>
Well, that and the fact the the VR6 isn't a 4cyl motor.
Steve
i haven't seen many vr6's over 200whp..</TD></TR></TABLE>Well, that and the fact the the VR6 isn't a 4cyl motor.
Steve
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by PhoenixTurboJesse »</TD></TR><TR><TD CLASS="quote">except it won't make that power
Nate R's 20 valve 4cly corrado made well over 200whp
i haven't seen many vr6's over 200whp..</TD></TR></TABLE>Nate R's 20 valve 4cly corrado made well over 200whp
Guest
Posts: n/a
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by k-series »</TD></TR><TR><TD CLASS="quote">
Steve</TD></TR></TABLE>
forgot about that
forgot about that
Black R
23
Mar 14, 2012 10:03 AM
BenMara
May 12, 2003 06:04 AM
Apocalypse
Nov 8, 2002 04:45 AM
