question about aluminum bodied cars and cages ie:honda insight and nsx's?
Old Feb 17, 2006 | 12:55 PM
dkim48's Avatar
Default question about aluminum bodied cars and cages ie:honda insight and nsx's?
I was just wondering this the other day...This goes for any factory aluminum bodied car.
1st question: Is the entire body aluminum? If not how do they tie the aluminum body panels to the steel chassis?
2nd question: If yes, then how do people go about welding steel to it? Are only bolt in style cages allowed?
I started thinking about this because of seeing all the drag insights and I read somewhere that they are aluminum bodied. I'm just trying to put one and one together. Thanks in advance
Old Feb 17, 2006 | 01:03 PM
TrueNorthStar's Avatar
Default Re: question about aluminum bodied cars and cages ie:honda insight and nsx's? (dkim48)
I would guess that you could just bolt some 8"x8" steel plates to the chassis/body and then weld the cage to that.
Old Feb 17, 2006 | 04:00 PM
dkim48's Avatar
Default Re: question about aluminum bodied cars and cages ie:honda insight and nsx's? (TrueNorthStar)
the thing is the drag cars that i have seen seem to have the stuff welded into the chassis...I don't think that 9 second drag cars can have bolt in cages...makes my brain hurt
edit: here is a picture for some answers-
Modified by dkim48 at 5:26 PM 2/17/2006
Old Feb 17, 2006 | 04:28 PM
sleepinEP3's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dkim48 &raquo;</TD></TR><TR><TD CLASS="quote">the thing is the drag cars that i have seen seem to have the stuff welded into the chassis...I don't think that 9 second drag cars can have bolt in cages...makes my brain hurt
Modified by dkim48 at 5:26 PM 2/17/2006</TD></TR></TABLE>
actually, they bolt it to the chassis.
Old Feb 17, 2006 | 08:23 PM
NJcoupe's Avatar
bisi!
Old Feb 17, 2006 | 09:55 PM
slammed_93_hatch's Avatar
if i a car is aluminum bodied does that mean that the entire car is made out of aluminum, i think not.
Old Feb 17, 2006 | 10:00 PM
tony1's Avatar
Default Re: question about aluminum bodied cars and cages ie:honda insight and nsx's? (slammed_93_hatch)
You bolt the floorplates in...
Old Feb 18, 2006 | 04:57 PM
dkim48's Avatar
Default Re: question about aluminum bodied cars and cages ie:honda insight and nsx's? (tony1)
so the entire car is made from aluminum? good to know
Old Feb 18, 2006 | 08:59 PM
RMF
Guest
Posts: n/a
What I did was .I got some thick wall Alum. tubing that the 1 5/8 chromoly would slide in perfect. Then I welded a long piece of tubing to a hole saw and cut a 2" dia. hole through where ever it went through the alum. body. Then I slid the alum. tube in the hole and then the chromoly tube to make sure it was in the correct place. And then welded the alum. tube to the body or firewall or where ever it went through.
And see the octagon shaped stubs in the front of the car ? I made steel octagon shaped box's and bolted to the original holes in it.
Modified by RMF at 10:12 PM 2/18/2006
Old Feb 19, 2006 | 07:10 AM
sc4dr's Avatar
Default Re: question about aluminum bodied cars and cages ie:honda insight and nsx's? (RMF)
Thats some inovative work there
Old Feb 19, 2006 | 12:01 PM
AllmotorEH2's Avatar
yeah no **** looks good
Old Feb 19, 2006 | 05:51 PM
xerox445's Avatar
Default Re: (AllmotorEH2)
You just use Alum tubing, duh
Old Feb 19, 2006 | 06:15 PM
RMF
Guest
Posts: n/a
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by slammed_93_hatch &raquo;</TD></TR><TR><TD CLASS="quote">if i a car is aluminum bodied does that mean that the entire car is made out of aluminum, i think not.</TD></TR></TABLE>
YES THE WHOLE CAR.Well this one is. Even all the front susp.I weighed that car with the motor and trans and most of the stuff I could think of, That goes on it .And it was right at 1000 lbs. I figured when it was done . It would need about 900 lbs added to be legal in allmotor street class.
Modified by RMF at 7:48 PM 2/19/2006
Throwdown
Jun 20, 2013 08:30 AM
GSRinmyCRX
Welding / Fabrication
Sep 12, 2011 06:27 AM
jononioo
Feb 2, 2006 05:46 PM
NiceCarsItsAllGood
Apr 2, 2003 06:16 PM
