Reving problem on a b18 LS motor swapped into a 88 crx
Old Feb 17, 2006 | 12:02 PM
x8_andrew_8x's Avatar
Default Reving problem on a b18 LS motor swapped into a 88 crx
My friend has a crx and when the motor gets warmed up its starts a random reving (goes up and down) constantly hes not too sure what it is he changed out the computer thinking it went bad but it still revs... PLEASE HELP me with this
Old Feb 17, 2006 | 12:28 PM
Kouki-EK9's Avatar
Default Re: Reving problem on a b18 LS motor swapped into a 88 crx (x8_andrew_8x)
Usually the first thing you look for when you have a fluctuating idle is vacuum leaks.
Old Feb 17, 2006 | 01:20 PM
Default Re: Reving problem on a b18 LS motor swapped into a 88 crx (Kouki-EK9)
yea but he had the problem before when it was in his 91 integra he got it swapped in his crx and it does the same i would figure that they would notice a leak if they had the entire motor out already im not too sure though im not a mechanic
Old Feb 17, 2006 | 01:31 PM
Kouki-EK9's Avatar
Hmm...I think vacuum leaks are the most common, but it could be a lot of other things. I'd say his best bet would be to have it looked at by a reputable mechanic.
Old Feb 17, 2006 | 05:16 PM
trrbl1bmx's Avatar
Its either IM gasket,idle air control valve, or vaccum. like mentioned above
x8_andrew_8x
Feb 24, 2006 08:03 PM
oLdsk0oLConCepTz
Aug 20, 2005 07:49 PM
liddlelude
Jul 29, 2002 02:09 PM
