Reving problem on a b18 LS motor swapped into a 88 crx
Old Feb 17, 2006 | 12:01 PM
x8_andrew_8x's Avatar
Default Reving problem on a b18 LS motor swapped into a 88 crx
My friend has a crx and when the motor gets warmed up its starts a random reving (goes up and down) constantly hes not too sure what it is he changed out the computer thinking it went bad but it still revs... PLEASE HELP me with this
Old Feb 18, 2006 | 12:28 AM
hybrid ef's Avatar
Default Re: Reving problem on a b18 LS motor swapped into a 88 crx (x8_andrew_8x)
it could either be the tps or if its not throwing any codes check the coolant level if your low and i mean real low when the motor starts to warm up it will begion to surge
Old Feb 20, 2006 | 10:57 PM
phildo1219's Avatar
Might be a vaccum leak, check the Tb and the vaccum lines make sure everythings connected, i had that problem when i changed out my TB and it reved up and down like crazy, gl with that
Old Feb 21, 2006 | 12:11 PM
rewerbcrx's Avatar
Default Re: Reving problem on a b18 LS motor swapped into a 88 crx (phildo1219)
vacuum lines... and grounds.
Old Feb 24, 2006 | 08:03 PM
95_red_dc's Avatar
what needed to swap in a b18b obd1 in to a crx si 91 thanks
ryan_crx
Oct 8, 2007 08:03 PM
x8_andrew_8x
Feb 17, 2006 05:16 PM
manyakiexpi
Feb 2, 2006 01:48 AM
DaMmniTz
14
Jul 16, 2005 06:34 PM
EndlessGarageEG6
Jan 31, 2002 08:57 AM
