WTB: motor mount brackets needed quick!
I still need the 99-00 civic si rear motor mount bracket! I'm desperate! Contact me ASAP!
Modified by burningwrek at 12:25 AM 3/12/2006
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by burningwrek »</TD></TR><TR><TD CLASS="quote">
The 94 + Integra transmission bracket that attaches to the motor mount from the top side of the transmission and....
The 94+ Integra transmission bracket from the front side of the transmission and... </TD></TR></TABLE>
U need to use the single cam bracket and for the front any b-series will work.
So all u need is the front torque mount bracket and the 99-00 Si rear motor mount bracket.
I don't know all the proper names for these brackets so bear with me. I've just about secured the rear Si bracket so I'm good there. I've got the sohc bracket for one on the top of the transmission. I'm still hunting for the one b-series bracket that fits the front of the transmission. So what about the bracket that is under the AC compressor? What can I use for that one? Thanks guys.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by burningwrek »</TD></TR><TR><TD CLASS="quote">I don't know all the proper names for these brackets so bear with me. I've just about secured the rear Si bracket so I'm good there. I've got the sohc bracket for one on the top of the transmission. I'm still hunting for the one b-series bracket that fits the front of the transmission. So what about the bracket that is under the AC compressor? What can I use for that one? Thanks guys.</TD></TR></TABLE>
If you want to use the Single cam a/c compressor you will need a del sol b16 a/c bracket. If you will not be putting a/c in then any dual cam bracket will work.
What bracket do u have for the timing belt side? Also is this going into an ek i assume?
PM sent, PoWeRBaN_PaNdA! I still need that ac compressor bracket from a b-series motor. For the bracket near the timing belt I'm using what came with my motor mount kit. the kit came with all the bushings and that one bracket but none of the other brackets.
Also, I need a reverse switch from a 94+ integra. My sohc one won't fit. Thanks guys!
Nbboy7
Apr 16, 2012 05:27 PM
TwoKSiR
May 18, 2007 10:12 AM
