shocks? wihch suspension can i use?
ok iknow EF and CRX shocks can work but what other shocks might i be able to use with a crx? would a 94 integra shocks work on a 88 crx? or a 91 integra suspension? if anyone knows let me know thanks
You don't want to use any of the 90-93 DA suspension because the stuts are longer than the rex's. I still believe you can use the front shocks off any 90-93 DA, just not the rear struts. I also believe that you can use 88-91 civic si struts.
wow thanks for the link....i guess i can't use DC shocks/springs on the CRX....i have a 88 and my friend is getting rid of his suspension on his 94 integra. i was thinking maybe i could use some shocks/springs but it seems like if i do shock travel and valves on shocks are little different...hmm guess i should just go for some crx suspension
if you understood the link, youd know the shocks would work if you used the front shock forks form an eg/dc. the springs would be questionable because the height would be off.
bad_azz_bmr
Aug 26, 2004 10:19 AM
