fuel
with a b16a swap in a 91 civic dx what would be the weakest part of the fuel system that i should worry about first(apex v-afc/fuel pump/injectors) and what is the correct fuel pressure for a 89 jdm b16a
From: A place where stupidity runs rampant aka NorCal
I have an apexi vafc in my car, along with a spoon chipped ecu (vtec on the spoon is 4400 which was way too low) and i seem to be running good so far on stock 150k mi pump and stock b16a injectors. I dont think ill ever max the injectors out with what i plan to do (cams, s2 mani, etc...) but i do have a 99 si fuel pump that will be going in sometime in the near future. Id say get your mods on, take it to a dyno with a wideband 02 and tune your a/f curve correctly and you wont have any problems.
Your fuel pressure should be around 42-46 psi at WOT. (vac. line off the regulator & plugged)
-Todd
-Todd
ShtNGit
Jul 23, 2007 05:46 AM
bmoser18
Aug 16, 2005 02:30 PM
