Question about the D15B7 in my 90 Si
Will the axles for the original CRX Si work with this swap? I am questioning this because I just had the passenger axle pop out, grease and bearings everywhere, and the rubber around the part that went into the transmission is shredded. The guy who had it before me did the axles. Did he mess up or does this swap need different axles?
if your still using an 88-91 d series cable tranny then yes your axles should work fine. he probrably never put the axle in right, the clip probrably did'nt seat right or might not have even been there. when you take the axle out make sure the clip is on the end of it, if its not, make sure its not in your differential and get a new one, along with a new tranny seal.
