will an obd1 integra harness fits my obd0 rex
i have obd1 d15b vtec engine on an obd0 intake mainfold and obd0 injectors, i bought obd1 dizzy and p08ecu, i tried to convert it to obd1 with a conversation harness but i didnt have spark, guys i want my vtec to work, so i thought to buy a whole obd1 harness, i found an integra one pretty cheap, will it work with my setup?! plz help
First, are you sure you know what you're doing. Second, search around. This swap topic has been covered alot. I'll give you a hint search DPFI-MPFI.
You cannot connect a OBD1 harness to your OBD0 CRX underdash/chasis harness and expect it to work. It will not work. If you bought a conversion harness and it doesn't spark then there is an issue in how you wired it.
first of all my crx was sohc zc, the las owner removed it and he put a vtec head d15b, so he kept the dizzy,tranny, injectors and intake mainfold. so i bought the obd1 dizzy, p08 ecu, and the coversation harness, i missed it up but i rewired it all over again wire by wire from the pinouts i found in HT, i wired the dizzy righ, but whe i instal everything it wont start, i just want my vtec before i add the turbo plz
