[FAQ] How To Rewire Seatbelt And Trunk Lights On Civic SiR EG6 Cluster With TCS
Old Feb 16, 2006 | 08:10 PM
BlueIntegraBoy's Avatar
Default [FAQ] How To Rewire Seatbelt And Trunk Lights On Civic SiR EG6 Cluster With TCS
I sure hope most people know that there are two types of Civic SiR2 (EG6) clusters. There are the ones without the door indicators with TCS, the most common ones; and there are the ones with the above options. The problem between the USDM clusters & the 'common' SiR cluster and the TCS SiR cluster is that the seatbelt light and trunk light are on the fuel/temp gauge as opposed to just having the seatbelt light on the fuel/temp gauge. With the trunk opened, the seatbelt light would turn on on the TCS cluster because the seatbelt light is where the trunk light would be. The trunk light is on the tachometer.
Without door indicators and TCS:
With door indicators and TCS:
1. Remove the dash bezel by removing the two screws above the cluster and the one behind the hazard button. Use a thin flathead screwdriver to pry the button and to pry the dash bezel from the driver side vent. Unplug the clock, if applicable.
2. Remove the four screws holding in the gauge cluster, two on each side. Next, unplug the plugs from the rear of the cluster.
3. You will be working on the 10-pin plug. As you can see the last two wires on the bottom are green and blue/white, respectively. The blue/white wire is your seatbelt light and the green wire is your trunk light.
4. On the plug, you will see a white piece of plastic. You will need to remove this piece by sliding it under the plug toward the wires. You will know what I am talking about when you look at it. Next, if you look inside the pinhole, you will see plastic hooks. These hooks hold the wire inside the plug.
5. Taking a medium sized safety pin, you will push down on that plastic hook while gently tugging the green and blue/white wires from the back to remove the wires.
6. Take the blue/white wire and move it into pinhole where the green wire came out off. Leave the green wire out of the plug. Reinstall the white plastic piece.
7a. To those with the two green plugs behind the tachometer, this next step will be easy. On the bottom green plug, you will see a green wire right in the middle of the plug. Hmm, green wire there and green wire that you just removed? Yup, they match. You will strip the insulator off the green wire coming off green plug. You will wrap this end around the metal pin on the green wire from that grey plug that you removed. Tape it up with black electrical tape. I do not suggest you solder it on to the pin incase you have to wire your harness back to a USDM cluster.
7b. To those unlucky not to receive the green plugs behind the tachometer, this next step will take a little more work. You will need to cut off the pin off the green wire that you remove from the grey plug. Then cut some off insulator off and solder that wire to middle prong. The downside is that if you have to remove the cluster for any reason, you will have to cut the wire. Another downside is if you have to rewire the harness again to accept a USDM cluster.
8. Reinstall everything
On another note: Those wanting to wire up the door indicators, I have not had time to play around with that since I just got this cluster a couple of days ago. Most likely you will have to tap off of the door sensor for the dome light and connect them to the two wires on the same green plug (off to the right in the above picture) as the trunk light.
Old Feb 16, 2006 | 09:25 PM
nocturnaldragon's Avatar
Default Re: [FAQ] How To Rewire Seatbelt And Trunk Lights On Civic SiR EG6 Cluster With TCS (BlueIntegraBoy)
Nice write up, should be beneficial to someone I'm sure.
Old Feb 16, 2006 | 11:28 PM
built562's Avatar
Default Re: [FAQ] How To Rewire Seatbelt And Trunk Lights On Civic SiR EG6 Cluster With TCS (nocturnaldragon
great write up man!
Old Feb 16, 2006 | 11:29 PM
I plan to wire up the door indicators on Monday.
Old Feb 16, 2006 | 11:38 PM
JDM_Ej's Avatar
HT Order of Merit
Community Builder
Community Influencer
Active Streak: 60 Days
Dude, where did you pick up that cluster that goes to 240km? I've been looking for that forever.
Wanna sell it?
Old Feb 16, 2006 | 11:59 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JDM_Ej &raquo;</TD></TR><TR><TD CLASS="quote">Dude, where did you pick up that cluster that goes to 240km? I've been looking for that forever.
Wanna sell it?
I just got it 2 days ago. I bought it off eBay. I've seen one about 4 months ago and lost my bid. I saw this and had to have it. It's a K's Meter Works speedometer. The only bad thing about it is when it lights up, the lighting is slightly more orange than the rest and the light dispersal is poor.
Old Feb 17, 2006 | 12:31 AM
JDM_Ej's Avatar
HT Order of Merit
Community Builder
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BlueIntegraBoy &raquo;</TD></TR><TR><TD CLASS="quote">
I just got it 2 days ago. I bought it off eBay. I've seen one about 4 months ago and lost my bid. I saw this and had to have it. It's a K's Meter Works speedometer. The only bad thing about it is when it lights up, the lighting is slightly more orange than the rest and the light dispersal is poor.</TD></TR></TABLE>
Ah that figures. I know Spoon made a 240km EG speedo, but you can't find that for less than 800$. I'll have to keep an eye out. Thanks!
Old Feb 17, 2006 | 12:41 AM
Ah that figures. I know Spoon made a 240km EG speedo, but you can't find that for less than 800$. I'll have to keep an eye out. Thanks!</TD></TR></TABLE>
cxSHOE can get a Spoon speedometer, but he requires a deposit.
Old Feb 17, 2006 | 12:44 AM
JDM_Ej's Avatar
HT Order of Merit
Community Builder
cxSHOE can get a Spoon speedometer, but he requires a deposit.</TD></TR></TABLE>
Yea i talked to him about it. Im not spending 800$ on a damn speedo though.
Old Feb 17, 2006 | 02:36 AM
Syndacate's Avatar
definately nice..
You should find out which year/models use the double greens behind the tach and which yers/models have to cut the prong (which seems like a lot of work)
Old Feb 17, 2006 | 09:07 AM
Default Re: (Syndacate)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Syndacate &raquo;</TD></TR><TR><TD CLASS="quote">definately nice..
You should find out which year/models use the double greens behind the tach and which yers/models have to cut the prong (which seems like a lot of work) </TD></TR></TABLE>
94-95 Civic SiR-S models had the the TCS option and thus the door indicators. Some other JDM models such as the VTi also had the door indicators. You can only get those plugs from that model. I'm not sure if any USDM Honda had those plugs (ie Accord).
Old Feb 17, 2006 | 09:35 AM
Relic1's Avatar
good write up.
making the door indicators work....
http://www.e-hatch.com/images/moto/doorlight.jpg
driver's door and passengers door are seperate in the car.
tap the wires for the door pins and run them seperately to the apropriate connections on the cluster.
Old Feb 18, 2006 | 01:40 AM
Default Re: (Relic1)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Relic1 &raquo;</TD></TR><TR><TD CLASS="quote">good write up.
tap the wires for the door pins and run them seperately to the apropriate connections on the cluster.</TD></TR></TABLE>
Awesome, thanks. Now I won't have to guess the wires. I was going to tap off the door sensor.
Old Mar 22, 2006 | 09:28 AM
Jdm Dina's Avatar
Default Re: (BlueIntegraBoy)
Has anyone figured out what usdm plugs will work on the back for the doors?
Old Jul 30, 2006 | 07:23 AM
Witwe's Avatar
Default Re: (Jdm EJ1 Coupe)
hmm....I'm too stupid to understand that
I have to add an additional wire for both doors to the indicator of the gauge cluster?
I thought that the wire on the left and right door is the same?
Or am I wrong?
and what is this indicator on the SiR gauge cluster standig for:
thanks,
Hannes
Old Jul 30, 2006 | 07:43 AM
Relic1's Avatar
If I remember correctly we covered this a while back. I think it was cat converter too hot or something like that.
(don't depend on my memory though)
Old Jul 30, 2006 | 09:26 AM
Default Re: (Witwe)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Witwe &raquo;</TD></TR><TR><TD CLASS="quote">hmm....I'm too stupid to understand that
Or am I wrong?
I wired up my door sensors, but never did a writeup. I tapped the door sensors that turn on the dome light on both sides. So I ran two wires. I forgot which pins those wires go to though.
Old Aug 26, 2006 | 08:03 AM
Lukezen_27's Avatar
Hi guys
Thanks for the info..
I’m installing an EG9 into my EG5 as we speak but there’s one thing I would really like!!
Dimmer Control?
Still dims the rest of the dash but not the cluster..
Thanks guys
LukeZen
Old Aug 26, 2006 | 10:18 AM
Default Re: [FAQ] How To Rewire Seatbelt And Trunk Lights On Civic SiR EG6 Cluster With TCS (Lukezen_27)
Yup, no dimmer control for the cluster.
Old Aug 26, 2006 | 10:55 AM
Lukezen_27's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BlueIntegraBoy &raquo;</TD></TR><TR><TD CLASS="quote">Yup, no dimmer control for the cluster.</TD></TR></TABLE>
Hi Blue
Might have to buy brighter bulbs then, coze mine’s a bit to dark
Anyone know the safe volt/watt of those little globs?
Any pic’s of that cluster at night?
I just brought this cluster some maybe he’s replaced em with weaker ones…
Thanks LukeZen
Old Aug 23, 2009 | 02:35 AM
K20egcw's Avatar
Bringin this back from the dead. Im wondering the same thing about the dimmer as well. Anybody figure out how to make it work with the dimmer switch? If somebody has a discriptive pic of the back of the cluster there is another guy on here that'll show how to make it work. Thanks
Old Aug 23, 2009 | 11:48 AM
Swap out the circuit film in the back with a non-JDM one
Old Aug 23, 2009 | 07:54 PM
ej1love's Avatar
sik cluuster
Old Aug 23, 2009 | 08:22 PM
mortificationrock's Avatar
in for some night pics of the cluster. All the ones ive seen are not in completely in the dark. Also i would appreciate a pic. Since im debating on wether to get the cluster or not.
Old Aug 24, 2009 | 02:41 AM
K20egcw's Avatar
Does that work for sure? Im not sure if I tried that when I first got it but im not sure. Thanks for the imput tho
