OEM or Aftermarket
Old Feb 16, 2006 | 07:58 PM
tdizz07's Avatar
Default OEM or Aftermarket
I just bought a 95 Civic EX and I need a new timing belt and a water pump and I was wondering if I should go buy the parts from honda and get the OEM parts or if it would be cool if I went to autozone or something and bought aftermarket because my budget isnt really flexable right now, and if it'd be a big difference I'd spend more but if it doesnt really matter I'll go to autozone
Old Feb 16, 2006 | 08:02 PM
G2 Speed's Avatar
Default Re: OEM or Aftermarket (tdizz07)
oem, the parts are farily cheap.... it's the install/labour that cost so much I think you can get both for under 200 or maybe less
Old Feb 16, 2006 | 08:04 PM
downeyballz's Avatar
i have alot of autozone pars on my cars and have had no problems. my goodyear/ gatorback timing belt has worked fine for a year
.Kevin.'s Avatar
Default Re: OEM or Aftermarket (G2 Speed)
i got mine at rockauto.com.... i think i paid like 40$ total... I dont think there is a diff but thats me im cheap
Old Feb 16, 2006 | 08:22 PM
G2 Speed's Avatar
Default Re: OEM or Aftermarket (Slow_CvC99)
i'm not saying one is better or not, but I would rather go with Honda brand for something so critical..
Old Feb 16, 2006 | 08:49 PM
The_Todd's Avatar
Farts in the shower
Buy from http://www.hondaautomotiveparts.com or http://www.slhonda.com for OEM parts for a non-so-OEM price .
Old Feb 17, 2006 | 12:47 AM
nello a.'s Avatar
oem or better than autozone aftermarket(toda,etc.) especially with regards to timing and water pump.
Old Feb 17, 2006 | 02:07 AM
Hern's Avatar
water pump id go to autozone, for a timing belt i would go to honda
Old Feb 17, 2006 | 06:27 AM
93bluehb's Avatar
OEM!
Old Feb 17, 2006 | 06:43 AM
hondamark35's Avatar
if you can find a gates brand belt it is of the same quality of the oem belt. as for the water pump, oem will keep you out of trouble later on. if you are doing it yourself don't forget to replace your cam and crank seals while you have it all apart.
Old Feb 17, 2006 | 08:08 AM
G2 Speed's Avatar
Default Re: OEM or Aftermarket (hondamark35)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by hondamark35 &raquo;</TD></TR><TR><TD CLASS="quote">if you can find a gates brand belt it is of the same quality of the oem belt. as for the water pump, oem will keep you out of trouble later on. if you are doing it yourself don't forget to replace your cam and crank seals while you have it all apart. </TD></TR></TABLE>
why would you replace your cams?
Old Feb 17, 2006 | 08:27 AM
jbs's Avatar
jbs
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by G2 Speed &raquo;</TD></TR><TR><TD CLASS="quote">
why would you replace your cams? </TD></TR></TABLE>
I think he means the seals . . . . "cam & crank seals"
Old Feb 17, 2006 | 08:32 AM
96hb's Avatar
I wouldn't skimp on something like a timing belt. Go OEM and have some peace of mind.
Old Feb 17, 2006 | 12:50 PM
G2 Speed's Avatar
Default Re: OEM or Aftermarket (jbs)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jbs &raquo;</TD></TR><TR><TD CLASS="quote">I think he means the seals . . . . "cam & crank seals"</TD></TR></TABLE>
alright lol
Old Feb 17, 2006 | 07:58 PM
Brick Top's Avatar
OEM
Old Feb 17, 2006 | 08:36 PM
iHEARTmyFERIO's Avatar
oem... it's a timing belt.. im cheap but i'd rather spend my hard-earned money on something that i'm sure will save me headaches later on...
Old Feb 17, 2006 | 09:22 PM
bmoua's Avatar
oem dude...
Syper
Nov 1, 2011 09:42 AM
laziebun
Apr 16, 2010 02:58 PM
guitarguru87
13
Nov 12, 2009 04:35 PM
jaxkxx
Nov 3, 2008 04:40 PM
Lucas_pln
Jan 24, 2007 11:23 AM
