1993 H22 Crank Pulley Bolt vs 1994-01 H22
Old Feb 16, 2006 | 07:57 PM
Yuleluder's Avatar
Default 1993 H22 Crank Pulley Bolt vs 1994-01 H22
It appears that I recieved a 1993 H22A1 block. I was going to use my crank shaft pulley bolt from a 1998 Prelude but, the threads in the crank were too small. I went to majestic honda and went through each year for the H22 and found that the 1993 H22 lude has a different threading. Here's what I pulled from there site.
26098 020 1 BOLT-WASHER (16X49) 1994-2001
93791 020 1 BOLT-WASHER (14X33) 1993
Has anyone else expereinced this?
Old Feb 16, 2006 | 08:13 PM
LudeyKrus's Avatar
Well I knew my 92 Si's H23 had a different bolt from the H22A1 I received, but I didn't know what years started w/ the bigger bolt.
Yes I've experienced it, no I didn't know the details about it.
Old Feb 16, 2006 | 08:40 PM
SnlpeR's Avatar
yes theyre different
i think its by years
during 93...there was a transition to use the bigger bolt
if you go to your honda dealer and ask them for a 93 prelude crank pulley bolt....it will show up with 2 different bolts
Old Feb 17, 2006 | 05:48 AM
Yuleluder's Avatar
Default Re: 1993 H22 Crank Pulley Bolt vs 1994-01 H22 (Yuleluder)
Does anyone know if the Torque Spec is different for the smaller Bolt?
Old Feb 17, 2006 | 08:33 AM
Yuleluder's Avatar
Whoever owns a helms manual for a 1993 Prelude SI VTEC, could you please see what the Torque Spec is for the Crank Pulley Bolt.
Old Feb 17, 2006 | 01:11 PM
flyrod's Avatar
159 ft-lbs (going from memory) I basically just put a wrench on it and hang from it.
Old Feb 17, 2006 | 01:16 PM
SteveoBA8's Avatar
Default Re: 1993 H22 Crank Pulley Bolt vs 1994-01 H22 (flyrod)
181ftlbs
Old Feb 17, 2006 | 01:19 PM
98TypeSH's Avatar
Default Re: 1993 H22 Crank Pulley Bolt vs 1994-01 H22 (SteveoBA8)
its 181 ft lbs for the 94+ bolts. its probably lower for the smaller bolt. expletive i dont know, i dont have a 93 helms
Old Feb 17, 2006 | 01:29 PM
Eddiebx's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by flyrod &raquo;</TD></TR><TR><TD CLASS="quote">159 ft-lbs (going from memory) I basically just put a wrench on it and hang from it.</TD></TR></TABLE>
your a light weight
ludekid4323
Mar 12, 2009 05:50 PM
92bluepreludeSi
Nov 22, 2008 12:48 AM
koreachangsu
Jul 28, 2006 07:19 PM
TheAccordGuy
Apr 21, 2006 10:36 AM
boostinh22
Dec 27, 2005 06:38 AM
