Where do you put oil into the tranny at??
Old Mar 27, 2002 | 10:51 AM
Toxic's Avatar
Default Where do you put oil into the tranny at??
Hey guys I'm just finishing my swap today. Swapping in a B18A. Now my tranny is drained, so where do I put the oil in at?? And also what oil should I use. a friend of mine mixed Mobile1 and regulr oil 50/50. Is that right??
Also if anyone who has done the B18A swap, could you please post pics, specifically of the intake manifold and firewall, I want to make sure I have my vacuum lines right.
Thanks
[Modified by Toxic, 7:54 PM 3/27/2002]
Old Mar 27, 2002 | 11:04 AM
REDBARON's Avatar
Default Re: Where do you put oil into the tranny at?? (Toxic)
Get the Honda MTF, it's the best.
Old Mar 27, 2002 | 11:07 AM
WuShu's Avatar
New User
Default Re: Where do you put oil into the tranny at?? (VTECHatch)
shairacer's Avatar
there should be a 17mm bolt on the right side of your transmission right next to where the right axle goes into the tranny. you need the funnel with the hose attached to fill the tranny with oil. hope that helps and good luck.
Old Mar 27, 2002 | 12:23 PM
slash00R's Avatar
New User
Default Re: Where do you put oil into the tranny at?? (shairacer)
yeah, it's hard as hell to get off too .. better prime it ahead of time with some wd40!
Old Mar 27, 2002 | 06:31 PM
Toxic's Avatar
Default Re: Where do you put oil into the tranny at?? (slash00R)
Thank guys
RexShop
23
Jul 20, 2006 08:02 PM
bossman032
Oct 9, 2003 09:24 PM
sir91
Aug 8, 2003 09:34 AM
xjoe
Dec 17, 2002 05:11 PM
