Type-R ECU into 01 GSR
Old Mar 27, 2002 | 10:45 AM
rsx03's Avatar
Default Type-R ECU into 01 GSR
I currently own a 2001 GSR. Someone is selling a 2000 ITR ECU and
if I get the ITR ECU will it be a direct PLUG & PLAY connection system, because the factory equipped the 01 GSR with a immobilizer system will I encounter any problems installing the new ecu into my car?
will it work ok? will my immobilizer system still work with my current key?
thanks guys
Old Mar 27, 2002 | 11:05 AM
fowler!'s Avatar
Default Re: Type-R ECU into 01 GSR (2K1GSRBOY)
I don't think that it will work with your key, but I'm not all to familiar with the immobilizer system.
Rather than buying a ITR ecu, just find a chipped P28 and a converter. Seems to me that it would work better.
Do you have a skunk2 manifold? You'll actually lose performance without it.
Old Mar 27, 2002 | 11:07 AM
ZygSpeed's Avatar
Default Re: Type-R ECU into 01 GSR (fowler)
Not only that, might have to watch the redline w/o ITR springs and valves!
Not to mention that the ITR ECU probably doesn't support working your secondary intake runners....?
[Modified by Zygspeed, 3:07 PM 3/27/2002]
Old Mar 27, 2002 | 03:57 PM
alexboy's Avatar
Default Re: Type-R ECU into 01 GSR (Zygspeed)
Redline you will be fine but if you have the stock intake manifold secondaries won't open
Old Mar 27, 2002 | 04:12 PM
Trey's Avatar
25 Year Member
Default Re: Type-R ECU into 01 GSR (alexboy)
The GSR will bog below 4400 rpms. If you get the ecu, get a Skunk2 manifold......
Old Mar 27, 2002 | 04:43 PM
alexboy's Avatar
Default Re: Type-R ECU into 01 GSR (Trey)
with itr ecu the crossover is to high so you'll need a vtec controller
Old Mar 27, 2002 | 04:45 PM
Looose_R's Avatar
itr springs are cable of hihger revs? hmmm
stock gsr's can rev to 8400 no problem on stock vavletrain
Old Mar 27, 2002 | 05:04 PM
nfn15037's Avatar
Default Re: Type-R ECU into 01 GSR (b20bastard)
Hell, i have a stock ECU and my VAFC always says 8462 when i shift at the strip.
Old Mar 27, 2002 | 05:38 PM
sa21199's Avatar
what about gsr's w/ R cams and R ecu? Can the rest of the valvetrain handle that?
Old Mar 27, 2002 | 05:41 PM
rsx03's Avatar
I actually plan on getting the SKUNK2 manifold and ITR cams too.
but really my main concern is the darn immobilizer system..will it work with my key.
or would i need to remove the system and how do i do that?
thanks!
Old Mar 27, 2002 | 06:59 PM
Looose_R's Avatar
Default Re: Type-R ECU into 01 GSR (nfn15037)
honda analog tacs arent very accurate at super high rpms
Moonpie9
Apr 8, 2003 04:25 PM
B00ST2nR
Mar 29, 2002 01:07 AM
comptechgsr
Feb 28, 2002 04:43 AM
1fastGSR
Aug 19, 2001 09:13 PM
