Cluster wiring -- Need help!
Old Feb 16, 2006 | 04:28 PM
1989CivicSi's Avatar
Default Cluster wiring -- Need help!
Alright, I've just about finished the wiring of my JDM cluster. Everything works great except...there are three yellow wires with red stripes! (The below image is for a CRX or something, the hatchback wiring is a bit different)
On my harness...
Slot 2 = Yellow + Red stripe with no silver dots
Slot 6 = Red + Blue stripe with silver dots
Can anyone tell me what these wires do?
Oh yeah, and Slot 4 for me in the below image is Yellow/Red with silver dots:
I'm really confused!
Modified by 1989CivicSi at 6:14 PM 2/16/2006
Old Feb 16, 2006 | 05:16 PM
Default Re: Cluster wiring -- Need help! (1989CivicSi)
Bump please, I have everything done but this!
Old Feb 16, 2006 | 07:58 PM
Seriously, bump for help! I just started my car again after sitting for a few months. Everything seems to be working (engine is growling to be driven hard ), but I'm sure at least 1 of these 3 wires does something!
Old Feb 16, 2006 | 08:58 PM
DieMaster's Avatar
Needs to be About 20% Cooler
i've allways wanted to kknow that too. and what the "not used" wires are for.
free bump though.
Old Feb 16, 2006 | 10:49 PM
Default Re: Cluster wiring -- Need help! (DieMaster)
Thanks mate. Lol, at least one of the above wires are indeed used. They're just all the same color haha. Well, they have silver dots too, but I still need to figure out which one is the right one for the JDM oil light?
Old Feb 17, 2006 | 01:49 PM
Bump for an answer.
Old Feb 17, 2006 | 06:31 PM
I heart My EF Sedan's Avatar
i believe one of the yellow/red is door open light... and the other yellow/red isn't used...
and red/blue is seatbelt i think...
Old Feb 17, 2006 | 06:41 PM
Default Re: Cluster wiring -- Need help! (I heart My EF Sedan)
Does anyone know for sure? I have an 89 so I wasn't aware that I even had the wires running from the doors. I know one of the three wires isn't used for sure, but what of the other two?
Bump for an answer
Old Feb 18, 2006 | 11:50 AM
Yet another bump. I know someone's done this to an 88-89 .
Old Feb 18, 2006 | 12:08 PM
crexer's Avatar
i feel your pain, i have an 88 dx and wiring in my jdm cluster is a biatch. Everything works except fuel, temp, and speedo. haha which is the most important things
Old Feb 18, 2006 | 12:09 PM
ghost_ryder35's Avatar
I'll give you a bump because I want to do this too.
Old Feb 18, 2006 | 12:13 PM
Default Re: Cluster wiring -- Need help! (ghost_ryder35)
Haha, everything actually works for me...but I just want to know what these last 3 wires are for (reason being because I actually made a diagram for this, but some of the wire colors are the same from the USDM harness).
Anyways, here's my diagram for 88-89 hatchbacks. Everything works/is correct with the exception of 1-2 wires...which I'm trying to figure out right now.
*Edit* I'm pretty sure the single wire I need to identify has something to do with the oil warning light.
Old Feb 18, 2006 | 02:45 PM
Jesus, I just figured it all out in less than a minute! The answer was sitting right in front of me (I feel so stupid). I plugged in the USDM clips into my CDM cluster, and traced the wires back to their sources (in this case, the warning lights). I found out that some of my wires were wrong, but most importantly -- I found out that the wires in question were actually for the...
A) Oil light --> (Big plug, yellow w/red stripe)
B) Seat belt light --> (Small plug, yellow w/red stripe (2) silver dots)
C) VSS -- ECU --> (Small plug, yellow w/red stripe but only (1) silver dot)
Using this method, I now know the function of each indivudial wire! I'm excited, because I now know that I can have a 100% functional SiR cluster . No guess/check/pray.
Actually, I now plan to re-use my mechanical VSS as opposed to swapping to an electronic VSS. Just need to double check some wires, and it should work with my original speedo/sending unit.
lsismore
Jan 13, 2006 01:14 AM
dutchman5
Feb 22, 2004 07:55 AM
racecarpete
Dec 23, 2003 07:23 AM
The G2 Racer
Oct 18, 2002 02:38 PM
