Front Lower Control Arm LCA help?
Anyone here remove their front LCA? I'm having a hard time separating the ball joint. I've use a 5 ton gear puller, and several different hammer whack methods and had no luck. Thankfully the crown nut is a soft metal of I would've stripped the bolt threads on the ball joint already
The Helms says to use a scissor type ball joint seperator, but if the gear puller couldn't do it, I can't imagine I will have much more luck with the scissor type bjs...
jermo
14
May 10, 2019 03:07 PM
s-tech
Aug 6, 2005 10:30 AM
ScottEK
17
Sep 21, 2002 06:23 PM
