88 crx hf fuel pump (this MUST be the problem)
Old Feb 16, 2006 | 04:12 PM
CoolRedXylophone's Avatar
Default 88 crx hf fuel pump (this MUST be the problem)
ok ive been working on this crx for a while now trying to get it to run.http://photobucket.com/albums/...3.jpg it turns over but will not start. i have
1. replaced the battery and battery cables
2. replaced the spark plugs and done an ignition check
3. put new gas in the tank
4. replaced the fuel filter
5. replaced the main relay
i removed the outgoing fuel line from the fuel pump to see if gas was reaching the engine and it wasnt. i was hoping the problem was the main relay before this, guess not
anyway my next guess is the fuel pump, yay.
the car has been sitting for about 4 years and was running before it was parked in a carport, could the fuel pump have gone bad during this time?
i just want to be sure this is whats wrong(im on a budget like many of us honda-techs)
any advice would be awesome
thanks guys
Old Feb 16, 2006 | 04:36 PM
Default Re: 88 crx hf fuel pump (CoolRedXylophone)
ill BUMP this once
Old Feb 16, 2006 | 04:50 PM
mahatma's Avatar
I guess you don't hear the fuel pump trying to run when you turn the key on?
Old Feb 16, 2006 | 04:53 PM
Default Re: 88 crx hf fuel pump (mahatma)
nope no noise
Old Feb 16, 2006 | 04:54 PM
mahatma's Avatar
It sounds like you know what to do
Old Feb 16, 2006 | 04:58 PM
ahhhhhh i just want it to runnn , im sure ill feel awesome when it finally does
Old Feb 16, 2006 | 05:08 PM
mahatma's Avatar
Actually man, on second thought you should at least test for power at the pump itself before you go dropping the tank and whatnot. Just to be sure
Old Feb 16, 2006 | 05:20 PM
yeah i plan to take a circuit tester to it tommorow
Old Feb 17, 2006 | 08:22 AM
incognito E46's Avatar
From: the greatest landscape architect is pictured above, gotta love the lack of home land security, socal
if you have a DMM, check for continuity on the connection side towards the fuel pump. you should be receiving batt voltage there. if not, check the connections on the dash fuse box and make sure there all connected.
i have the same problem as you so hope this helps
crxricer66
Oct 15, 2007 05:39 AM
curioso
Sep 19, 2007 05:06 PM
jakscivic
10
Aug 9, 2007 11:21 PM
CoolRedXylophone
Jan 21, 2006 08:59 AM
progressivedrunk
Oct 19, 2003 05:45 PM
