Suspension & Brakes Theory, alignment, spring rates....
axles wont go in.
Old Feb 16, 2006 | 03:41 PM
Bserieskiller's Avatar
Default axles wont go in.
i need some help. please help me. okay i just installed my clutch and flywheel and now i'm having a problem putting my axle in the passenger side and driver side in. it seems like somethings blocking the way. someone help me please.
Old Feb 16, 2006 | 04:00 PM
PIC Performance's Avatar
Default Re: axles wont go in. (darkoe6)
Won't go into where? Into the hub?
Old Feb 16, 2006 | 04:02 PM
Tyson's Avatar
the circlip is just being difficult. you just need to force it in.
get a block of wood, put it at the end of the axle and hammer it in. (dont do without the wood, or youll mess up the axle tip)
or you can try use the knuckle to swing the axle in. have the tie rod and bottom balljoints popped off, and fasten the axle nut, and just pull back and swing it in.
Old Feb 16, 2006 | 06:30 PM
Default Re: axles wont go in. (Tyson)
thanks. i'll give it a try
ralphieg
Oct 2, 2012 06:36 PM
swarley
Transmission & Drivetrain
Jan 28, 2011 06:56 AM
Bserieskiller
Feb 16, 2006 03:39 PM
tecnic1
Jul 11, 2003 07:23 PM
ill phil
May 15, 2003 06:27 PM
