Subwoofer/voicecoil
Old Feb 16, 2006 | 03:19 PM
PnoyJeff's Avatar
Default Subwoofer/voicecoil
is it necessary to use all the voice coils of a sub?
or is it ok to just use one...would it do any harm?
make a significant change in sound?
my sub is a quad 2ohm voicecoil
also..is it possible to hook up all the positive terminals together, tape it together n put it in the positive amp terminal..n then the same for the negative
Old Feb 16, 2006 | 03:58 PM
wrx-killer-Sti-eater's Avatar
From: 99 probs but a stolen car aint 1, ca, cerritos/fullerton
Default Re: Subwoofer/voicecoil (PnoyJeff)
This is a big debate over here. You can run one set. But some companys void warrentys if one set is hooked up. I prefer to do what the company says on there subs because they are the ones who made it. One of my custemer is running like this because he blew one of his vc. It was a dual 4 ohm. He is now running it as a 4 ohm sub for the past 4 months with no problem and it still hits. not as hard because it not pulling that much power from the amp. but is decient.
Old Feb 16, 2006 | 04:10 PM
PnoyJeff's Avatar
Default Re: Subwoofer/voicecoil (wrx-killer-Sti eater)
im not quite sure on how to wire all of them together..
do i just do something like take all of the negative terminals n put them together n run that to the negative on the amp. n then do the same for the posivie?
Old Feb 16, 2006 | 04:27 PM
first you need to know were your amp is stable at. You dont want to run the amp at a low ohm rating if it cant take it. What amp are you using and what sub? Hit me with that info and we can help you better
Old Feb 16, 2006 | 04:54 PM
PnoyJeff's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by wrx-killer-Sti eater &raquo;</TD></TR><TR><TD CLASS="quote">first you need to know were your amp is stable at. You dont want to run the amp at a low ohm rating if it cant take it. What amp are you using and what sub? Hit me with that info and we can help you better </TD></TR></TABLE>
Amp is a PowerAcoustik A3000DB
Sub is a Audiobahn AWIS10P
Old Feb 16, 2006 | 05:25 PM
okay let get you taken care of. First the amp you have will only put out 1600 watts rms. I know it says this but I just talked to one of there tech. The numbers you got were from a ideal enviroment. at 16 volts. a cool room. perfect signal. But thats good because your sub rms is 1500 watts. Your sub is a dual four ohm vc so you are going to wire it up parellel, Pos to pos and neg to neg. This will give you a two ohm load to your amp. Since your amp is one channel. They made it with a two channel speaker output which is just two mono output. don't bridge it just connect it to one side and your amp will be running mono at a 2 ohm load.
riceball777
Audio / Security / Video
Oct 7, 2006 12:44 PM
Intrepidv614
Dec 13, 2005 05:02 PM
92ehatch
Nov 28, 2005 02:18 AM
cd5_2NR
Mar 21, 2004 03:28 PM
101998
Nov 3, 2002 08:47 PM
