Fuel volume/pressure check
Old Feb 16, 2006 | 02:06 PM
goirish's Avatar
Default Fuel volume/pressure check
how do i check and see if my fuel pump is working sufficently. dont want to go up in smoke!
Old Feb 16, 2006 | 02:37 PM
frontwheelin's Avatar
Default Re: Fuel volume/pressure check (goirish)
I'm not expecting you to have one but if you have a fluke meter or something along the lines of that with a inductive amp clamp you can "amp ramp" but when all else fail get a fuel pressure guage that would probably be the easiest way i could think of.
Old Feb 16, 2006 | 03:47 PM
P_Adams's Avatar
Traditionally, a tech will install a mechanical fuel pressure gauge in the fuel line so as to sample the system real-time (both at idle and while driving)
What pressures you're looking for:
Carbureted: 4-6psi (28-41 kPa)
Fuel Injected: 38-46psi (260-310 kPa)
P
gabrielsousa
Apr 16, 2014 05:17 AM
Dominic-CTR
Oct 24, 2004 04:08 AM
Mike1486
Oct 7, 2004 09:27 AM
