Honda S2000 Honda S2000
ECU Honda S2000
Old Feb 16, 2006 | 12:55 PM
veut's Avatar
Default ECU Honda S2000
Who knows what pulses go from contact A1(32p) ecu S2000 On a gauge cluster a cooling liquid of the motor(yell\green-wire)
http://a.photofile.ru/image.ph...ger=5
Modified by veut at 2:24 PM 2/16/2006
Old Feb 16, 2006 | 01:05 PM
Mr. Projekt's Avatar
* B A N N E D *
Default Re: ECU Honda S2000 (veut)
Your ABS light is on, you're missing that infamous 1 bar, so it looks like an AP1. Now what was your question?
Old Feb 16, 2006 | 01:32 PM
veut's Avatar
Default Re: ECU Honda S2000 (Slideways2000)
problem not.All Ok!!-in car))) But I ask up..Look please all my foto))
http://a.photofile.ru/album.php?id=614193&pager=4
I have Civic- EK4-SIR-B16A6 and gauge cluster S2000))
Old Feb 16, 2006 | 02:09 PM
* B A N N E D *
I see... You put it in a Civic... Now what was your question?
Old Feb 16, 2006 | 02:34 PM
veut's Avatar
Gauge have one wire-yellow\green....Whots info ? sorri-problem write for enqlish))
Old Feb 16, 2006 | 02:48 PM
* B A N N E D *
Yellow/Green is the circuit for Engine Coolant Temp sensor, which goes through the ECU.
Old Feb 16, 2006 | 08:09 PM
veut's Avatar
I see)) what pulses go ??
Old Feb 25, 2006 | 12:50 PM
veut's Avatar
1-I have Civic -EK4-P2T-B16A6-SiR
2-I have s2000 cluster--he work in my car 99%
3-but in the cluster not work small scale temperature motor because p2t dont have digital out for cluster(only analog signal)
4-If I want ecu s2000 on my table-I can look through digital impulses on yellow\green wire(A1-32 pin connector)
5-then I think what doing next))))
Old Feb 25, 2006 | 06:10 PM
Kenso's Avatar
HT White Ops
If I understand correctly, you're trying to make the s2000 cluster work with the signal from the coolant temperature sensor on your civic. As you seem to have figured out, the S2000 ecu converts the coolant temp sensor signal into a pulsed signal, which is then sent to the cluster. Guys who run the AEM ecu have the same problem, and apparently someone has developed a converter to modify the signal to the gauge. Here's a link to the "converter".
http://www.modifry.com/products/index.htm
Here's a thread which explains how the stock S2000 ecu converts the signal from the sensor.
http://www.s2ki.com/forums/ind...&st=0
Old Feb 26, 2006 | 08:27 AM
veut's Avatar
Default Re: ECU Honda S2000 (Kenso)
97_dc2
Aug 26, 2014 08:10 AM
crx^2yosolo
14
Dec 27, 2005 05:42 PM
