VTEC/IDLE SPUTTER???
Old Feb 16, 2006 | 11:49 AM
naha08's Avatar
Default VTEC/IDLE SPUTTER???
I have a 2000 base prelude with 50K mile on it. I was trying to pass a car yesterday and when VTEC engaged it was sputtering and broke-up, almost like it was misfiring. When I drive normal it drives perfect. Then today I was sitting at a light and it started to sputter again and dropping about 50-70 RPM’s just for a second then would idle fine. I did a full tune-up about two months ago, and I went home and added some oil incase that was the problem but it’s still doing it. Oh and I am throwing no cel’s. It’s probably a damn sensor. Any help would be great. Thanks.
Old Feb 16, 2006 | 06:12 PM
iLude's Avatar
Default Re: VTEC/IDLE SPUTTER??? (naha08)
Check your O2 sensor.
Old Feb 16, 2006 | 06:43 PM
CivicSiDriver02's Avatar
Maybe you just got a bad tank of gas?
Old Feb 16, 2006 | 06:54 PM
jdmlude_dude's Avatar
Default Re: VTEC/IDLE SPUTTER??? (CivicSiDriver02)
i have a similar problem however not in Vtec only at idle. I changed o2 and that didnt work. About the only thing i havent changed is my rotor in my distributor.
Old Feb 17, 2006 | 01:13 AM
y0whuddupb's Avatar
Default Re: VTEC/IDLE SPUTTER??? (jdmlude_dude)
sounds like the same problem i had a few weeks back. all that sputtering and everything finally built up and my crank angle sensor failed. replaced whole dizzy and works fine since. but my ECU has gone bad now. check the Dizzy see if there is alot of play on it.
DanielSLe
21
Jan 16, 2023 10:14 PM
JustG
Jan 15, 2010 06:24 PM
candymanjl
Oct 6, 2006 05:00 PM
JDMlyfestyle
Nov 13, 2003 01:59 PM
balldipperMP
Dec 10, 2002 07:43 AM
