Ls/vtec with ls pistons...
Old Feb 16, 2006 | 10:27 AM
stockb16hatch's Avatar
Default Ls/vtec with ls pistons...
Whats up yall....I have a stock 97 ls,and looking to go vtec but i was told an ls/vtec with ls pistons is slow as ****,and i was thinking would b16 pistons make such a diff..?everyone i know says yeah,but i just dont see the point in changing to other oem pistons..?And what head should i buy...?Im looking for around 200 whp,Can it be done with 1.8,stock rods,and just some cams/intake mani/header and valetrain..?Thanks.
Old Feb 16, 2006 | 10:41 AM
D-Rob's Avatar
Default Re: Ls/vtec with ls pistons... (stockb16hatch)
If you're looking for 200whp on stock internals, go with P30 (B16) pistons.
The reason is, B16 pistons have a larger 'dome,' thus increasing compression from about 9.6-8:1 with the PR4 (LS) pistons to about 11.5-7:1 with the P30's, depending upon, of course, which head you choose to run.
200whp all motor isn't happening on stock PR4 pistons.
- Derek
Good luck.
Old Feb 16, 2006 | 11:25 AM
b20vtech's Avatar
CTR PISTONS ALL THE WAY...........MAKES THE BEST POWER OUT OF 81-81.5mm HONDA OEM PISTONS
Old Feb 16, 2006 | 02:14 PM
D-Rob's Avatar
Default Re: Ls/vtec with ls pistons... (b20vtech)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by b20vtech &raquo;</TD></TR><TR><TD CLASS="quote">CTR PISTONS ALL THE WAY...........MAKES THE BEST POWER OUT OF 81-81.5mm HONDA OEM PISTONS</TD></TR></TABLE>
You need to lay off the crack.
In an LSVTEC, you can make more power with P30's or P73's than those piece of crap PCT (CTR) pistons.
Ask any seasoned builder and he'll tell you why.
Hint, it has to do with effective compression on pump gas, and flame travel within the cylinder.
CTR pistons aren't worth it.
If you want more than 11.7:1 compression, use P30's, and mill the head.
Old Feb 16, 2006 | 02:21 PM
anthony90si's Avatar
how about the pr3's? i don't think there is that much of a difference and prob easier to come accros.
Old Feb 16, 2006 | 02:29 PM
DC2 Mang's Avatar
Default Re: (anthony90si)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by anthony90si &raquo;</TD></TR><TR><TD CLASS="quote">how about the pr3's? i don't think there is that much of a difference and prob easier to come accros. </TD></TR></TABLE>
PR3's have about the same dome as the JDM ITR pistons and will give you a good compression for pump gas as well
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by D-Rob &raquo;</TD></TR><TR><TD CLASS="quote">
I agree, CTR pistons are crap for an LSvtec, they are heavy and increase lateral stress on the LS rods, and give you a retardedly high compression for pump gas
97L-esVeeTeg's Avatar
CTR's, ITR's, or B16's, will do fine, it really depends on goals, desired compression, and what is going to be used to tune.
My best advice is to ask your builder.
200+ has been made many a time utilizing all of the above choices.
Build a solid bottom, and squeeze your power out of your head.
Old Feb 16, 2006 | 03:28 PM
gutted-dx's Avatar
So CTRs are to much for a daily driver
Old Feb 16, 2006 | 04:39 PM
WHITFIELD-TUNED's Avatar
DYNO-PRO
From: SoCal I.E 909, CA, where we innovate not immitate
Default Re: (gutted-dx)
p30's IMO
Old Feb 16, 2006 | 07:49 PM
cisurfer1's Avatar
CTR'S by far, my friend made 211 using mostly oem parts, the ctr's over b16's any day of the week
Old Feb 16, 2006 | 09:04 PM
Default Re: (cisurfer1)
Thanks for the replies guys....Looks like im going to need some CTR's..
Old Feb 17, 2006 | 11:48 AM
Expletive!'s Avatar
Default Re: (stockb16hatch)
You can make 200 WHP on a stock block.
Modified by Slaughter at 1:07 PM 2/17/2006
Old Feb 17, 2006 | 01:41 PM
D-Rob's Avatar
Default Re: (Slaughter)
Not with stock LS pistons all motor.
People around here need to lay off the drugs, lately.
Old Feb 17, 2006 | 01:51 PM
foumer's Avatar
W95 gives me a hard-on
ls/vtec with ls pistons are kinda weak. I have one. Best 1/4 mile I got of it was 14.8 on street tires untuned. Beat alot of gsr civics though .
Old Feb 17, 2006 | 01:55 PM
D-Rob's Avatar
Default Re: Ls/vtec with ls pistons... (foumer)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by foumer &raquo;</TD></TR><TR><TD CLASS="quote">ls/vtec with ls pistons are kinda weak. I have one. Best 1/4 mile I got of it was 14.8 on street tires untuned. Beat alot of gsr civics though . </TD></TR></TABLE>
Depends of what car you have it in. If you've got it an an EK coupe, then that time isn't bad.
Old Feb 17, 2006 | 11:42 PM
stockmr2's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by stockb16hatch &raquo;</TD></TR><TR><TD CLASS="quote">Thanks for the replies guys....Looks like im going to need some CTR's.. </TD></TR></TABLE>
i got some non oem ctr pistons for sale *new*
Old Feb 18, 2006 | 08:56 AM
Colt Seavers's Avatar
Default Re: Ls/vtec with ls pistons... (D-Rob)
Someone need's to make a post asking if CTR pistons are junk. I'd bet that
most people would say "YES" they are garbage.
Old Feb 18, 2006 | 10:11 PM
DC2 Mang's Avatar
Default Re: Ls/vtec with ls pistons... (Colt Seavers)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Colt Seavers &raquo;</TD></TR><TR><TD CLASS="quote">Someone need's to make a post asking if CTR pistons are junk. I'd bet that
most people would say "YES" they are garbage. </TD></TR></TABLE>
I am on the yes side of this argument
there is is whole thread about CTR/ PCT pistons about 20 pages long, if someone hasnt read it already i would suggest reading it, it will explain the issuses of undercaming and over caming with theses pistons in an lsvtec
Old Feb 18, 2006 | 10:16 PM
whoa its len 2's Avatar
pr3 and p30 pistons will work with pr4 rods no modification needed
Old Feb 18, 2006 | 10:17 PM
Expletive!'s Avatar
Default Re: (D-Rob)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by D-Rob &raquo;</TD></TR><TR><TD CLASS="quote">Not with stock LS pistons all motor.
People around here need to lay off the drugs, lately. </TD></TR></TABLE>
I have 2 friends as of this very minute on STOCK LS BLOCKS WITH STOCK LS PISTONS that made about 192-195 on very bone stock blocks. so yes..with stock LS pistons you can make 200 WHP. And both set ups were mildly built heads. Dare me to prove anyone otherwise?
So i'll keep taking drugs and keep the very nice thought of 200 WHP, 12 SEC. ET's on stock blocks in the back of my head thank you very much
Oh and one of them went 12's in an EK coupe, stock block LS, and on a POS DC 2 peice 4-2-1 header.
Modified by Slaughter at 4:13 AM 2/19/2006
Old Feb 19, 2006 | 06:24 AM
D-Rob's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Slaughter &raquo;</TD></TR><TR><TD CLASS="quote">
Modified by Slaughter at 4:13 AM 2/19/2006</TD></TR></TABLE>
I assume you have proof?
Because I would REALLY like to see this. 12's in an EK coupe all motor using a stock bottom-end LSVTEC.
Damn, I, as well as many other people here, must be building something wrong when we need over 10:1 compression and big cams to make 200whp and run those kind of times.
Old Feb 19, 2006 | 06:47 AM
foumer's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by D-Rob &raquo;</TD></TR><TR><TD CLASS="quote">Depends of what car you have it in. If you've got it an an EK coupe, then that time isn't bad. </TD></TR></TABLE>
Well yeah I shouldnt bash my baby. Has been running strong for 2 years now without a problem even though the block has atleast 190k miles (rebuild coming soon). I have it in a 94 eg dx coupe. I also have a b16 tanny with it.
wow 200hp on stock ls/vtec, there is probably some laughing gas involved in there
Old Feb 19, 2006 | 11:34 AM
LSVTEC 91 Civic's Avatar
Banned
I like my CTRs
Old Feb 19, 2006 | 12:21 PM
Expletive!'s Avatar
Default Re: (D-Rob)
Damn, I, as well as many other people here, must be building something wrong when we need over 10:1 compression and big cams to make 200whp and run those kind of times. </TD></TR></TABLE>
I dont have **** on paper..but i have living proof. Milogen Fab here on H-T he used to go by NorxCal did it..in his EK coupe. Another friend of mine thats not on here did it in an EG. Stock block LS vtec's. Its all in your head..and by being an all motor person..you know that. The coupe i believe is getting some b16 piston's as of now..but rest assure he did that with a stock block. and he's only tyring to go faster.
Old Feb 20, 2006 | 04:37 AM
D-Rob's Avatar
I don't care how well your head flows, with the compression using stock PR4 pistons, you can't utilize big cams as well, thus not making as much power.
I want solid evidence.
