88 accord Lx, auto, frequent stalling after warming up & hard left turn HELP
Old Feb 16, 2006 | 09:47 AM
robertk's Avatar
Default 88 accord Lx, auto, frequent stalling after warming up & hard left turn HELP
Problem
1. after engine heats up and driving on road, suddenly stalls. restarts, then normal
2. after engine heats up, hard left turn, suddenly stalls. restarts, then normal
3. after engine heats up, in neutral, in the garage, reving to about 3K, suddenly stalls. restarts, then normal
Replaced
1. have 3/4 tank gas
2. replaced front & rear fuel filters
3. replaced ignition coil
4. replaced fuel pump
5. jumpered fuel cut off relay, condition same: relay not the problem
Any checks I can conduct to check out the distributor? ignitor or pick up. I don't want to replace and this is not the problem.
Could also be the carb idle speed/mixture. got to remove the carb to access adjustment and i need a propane test fixture
appreciate any help, suggestions
Ludeboi
Oct 19, 2005 10:07 PM
Crolya
Jul 21, 2005 11:34 AM
kolyan
Jan 21, 2005 05:21 PM
Accord1980
Jan 29, 2003 01:28 PM
