Need advice
It's an excellent setup for either; but not at the same time. You can have any rate to suit your needs on the GCs, but the rates you need are different for street and track.
I'm running 400/500 rates and it's pretty uncomfortable on the street, but I could use higher rates on the track. It's a compromise.
I'm guessing you'll be mostly cruising around, so start with the standard rates, and go from there. You don't need a camber kit, but you do need to get an alignment.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by rlyoung »</TD></TR><TR><TD CLASS="quote">your looking at about 400-450 for the parts you mentioned save up the extra 250 and get the tein basic coilovers they should suit your needs well!</TD></TR></TABLE>
That setup has nothing on a good GC setup.
I was looking at the Tein's too. I will probly go that route, but I do need a camber kit because I can't adjust camber on my car, there's simply no way too, I'm in an auto tech class right now and doing just alignment isn't enough.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Hatchorama »</TD></TR><TR><TD CLASS="quote">I was looking at the Tein's too. I will probly go that route, but I do need a camber kit because I can't adjust camber on my car, there's simply no way too, I'm in an auto tech class right now and doing just alignment isn't enough.</TD></TR></TABLE>
Tein is the best idea
illuminas are a great shock and reasonably priced too.
pro kits are a great street spring. a decent drop, but wont have to always worry about scraping either. stiffer than stock, but still comfortable. i autoxed and did track days with these springs, i always had fun. it wasnt until i was really competitively racing that i needed to change to a custom rate. i think youll be fine with these springs.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Tyson »</TD></TR><TR><TD CLASS="quote">pro kits are a great street spring. a decent drop, but wont have to always worry about scraping either. stiffer than stock, but still comfortable. i autoxed and did track days with these springs, i always had fun. it wasnt until i was really competitively racing that i needed to change to a custom rate. i think youll be fine with these springs.
I agree. I ran many track days with my Koni/pro-kit setup and no sway bars. It isn't the fastest out there, but when you're starting out it doesn't matter much. You're going to be slower than your suspension can handle anyway.
as for a good camber kit. It won't be needed for this setup anyway, just get a good alignment and hit the track
RippSpeed
Suspension & Brakes
May 4, 2007 12:50 PM
