Stock Sleeves or Aftermarket?
Old Feb 16, 2006 | 06:57 AM
HatchedGTI's Avatar
Default Stock Sleeves or Aftermarket?
I'm trying to do an All motor build aimed at around 220whp. I want to bore it out to 82mm and stroke it to 92mm so I would be like a 1.95L I believe. Now I am wondering whether it would be possible to make 220whp with that displacement on a daily driven compression.. Meaning running 93 octane. The head would be a port and polished GSR head with a ferrera valve train. So basically I was wondering whether it would be possible for a SOMEWHAT reliable daily driver to hit 220whp with stock sleeves. Thanks
Modified by HatchedGTI at 4:10 PM 2/16/2006
Old Feb 16, 2006 | 07:24 AM
92TypeR's Avatar
FSAE
Default Re: Stock Sleeves or Aftermarket? (HatchedGTI)
There are a few 1.8L's making over 220whp.
Your power will primarily come from headwork, a good header, and the right combination of cams.
https://honda-tech.com/zerothread?id=1415895
As for the compression for pumpgas, it all depends on how big a cam you want to run. Large cams bleed off a lot of compression, so it is possible to have 13:1 compression or higher and still run safely on 93 octane. If you stick with a mild cam, compression in the low 12:1 area would be ideal.
Old Feb 16, 2006 | 08:46 AM
EHondaD6's Avatar
Default Re: Stock Sleeves or Aftermarket? (92TypeR)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 92TypeR &raquo;</TD></TR><TR><TD CLASS="quote">There are a few 1.8L's making over 220whp.
As for the compression for pumpgas, it all depends on how big a cam you want to run. Large cams bleed off a lot of compression, so it is possible to have 13:1 compression or higher and still run safely on 93 octane. If you stick with a mild cam, compression in the low 12:1 area would be ideal.</TD></TR></TABLE>
i agree...
crazydominicanman
40
Aug 30, 2011 12:25 PM
thegatekeeper14
13
Dec 24, 2010 09:11 AM
hpwdhatch
Nov 6, 2006 02:52 PM
IGotVTECyo
Jul 7, 2005 06:41 PM
Ti3d in
Jul 11, 2004 02:45 PM
