Body part interchangability from a 88 to 91???
Hey guys I have a couple of questions. I checked the sticky/FAQ but i didnt see it mentioned.
Will 88 CRX HF Fenders fit on a 91 CRX Si with no moddding? Are they the EXACT same thing? If not what are the differences and mods i will need to make it work?
What about the headlights. I believe there slightly different but what about the mounting hardware? Is that the same?
What about the side view mirros? Same?
Thanks
Thanks
the fenders should fit. The headlights are the same, but the brackets are different. The headlight to bracket bolts are the same to the brackects are interchangable, the only difference between the two is where the brackets bolt to the frame. So just swap the brackets
The fenders will fit if you get the 88-89 corner lights, because they are different than the 90-91 corner lights, but the fender will bolt up exactly with the same bolt pattern. And yes the side mirrors are the same, and will work. Go for it!
spens 91 Ef
Apr 15, 2009 08:38 PM
Eli2
Mar 25, 2009 06:15 PM
acmoc
Dec 13, 2008 12:30 PM
crx_ef8
Feb 21, 2005 03:24 PM
