94-96 Center console
I own a 92 prelude and want to do the 94-96 center console, so i can gut the back of the car, but i was noticing the e-brake is off to the side in in the 94? Is it easy to move it or you cant? has anybody ever done this, if so is there a write up. Oh yeah do u think that 45 is a lot of money for the console at my local junk yard, the cup holder was broken, by broken i mean it wouldnt close.. thanks
I believe the 93 uses the same front console as the 92 but doesnt go into the back seats that might be easier. it also uses the same e brake.
the 94-96 actually uses a different e brake and you would need to pick that up too. which shouldn't be hard since you are already getting the console.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by kulrevon »</TD></TR><TR><TD CLASS="quote">I believe the 93 uses the same front console as the 92 but doesnt go into the back seats that might be easier. it also uses the same e brake.
That's correct, if I wanted a 95 console in my 93 (wich I do) I would also need to change my e brake.
actually the ebrake cables for the 94-96 console are longer, and you will also need another base plate to connect the ebrake lever to the side of the console. I was looking into the same thing for my 93, wanted a bolt-in and go deal but it takes a lil extra work to make it fit.
i got a 92 and i was able to make the 95 armrest one work. u have to make a base plate. i used flat 1/4"x 2" aluminum that i just had lying around bolted it to the car then drilled and bolted the 96 e-brake to it. i used my stock cables but i had to unbolt them from the underside of the car and pull them into the car more to reach to my e-brake. works good but looks 300 times better with my cupholder and armrest. maybe later i could get some pics up of my install.
