? - What AMP to get for 2-12" Momo Polk Audio MM120
Old Feb 16, 2006 | 12:45 AM
Bone Stock's Avatar
From: City of fakeJDMs but their vT3s HiT H3ll4 L0uD...., usa
Default ? - What AMP to get for 2-12" Momo Polk Audio MM120
Just like the title says i got 2 12" momo polk audio MM120 subs. I want to know what aMp to get that will set these babys on fire (not actually on fire)...And if you had these subs let me know how they were and if you have any more info on these subs on how good they are i would really appreciate it
Driver Complement
Woofer 1 - 12" Diameter (30.48cm)
Poly/Graphite Composite Cone
Electrical
Overall Frequency Response 20-200 Hz
Nominal Impedance 4 ohms
Power Handling (continuous) 500 w
Power Handling (peak) 1000 w
Efficiency 87 dB
Voice Coil Diameter: Driver 2" (5.08cm)
Magnet Weight 66.00 oz.
Driver Mounting Depth
Top Mount 6-313/10000" (15.32cm)
Bottom Mount 6-1/2" (16.51cm)
Cut-out
Driver Cut-out Diameter 11-1/8" (28.26cm)
Theile/Small Parameters
Recommended Enclosure .88 cubic foot sealed
Resonant Frequency 30 Hz
Qms 8.06
Qes 0.50
Qts 0.47
Vas 2.15cu ft. / 61L
Cms 164 Micro Meters
Bl 15.5 Tesla Meters
Sd .553 sq ft / .0514 sq m
Winding Width 1.0 in / 25.4mm
Xmax (linear) .3343 in / 8.7 mm
Xmax (mechanical) 1.0 in / 25.4 mm
Le 1.3 mH
Mms 173.9 g
Driver Weight 15lbs 2 oz / 6.8kg
Vd .062 cu ft
sumdewd
Audio / Security / Video
May 17, 2012 05:22 PM
TegoDC5
Jan 24, 2005 11:10 AM
Hibrid
Jan 16, 2004 02:15 PM
FBP Si 2000
Dec 18, 2003 02:05 AM
CereaLand
Feb 1, 2003 11:45 AM
