HELP: lights dont come up on heater/ac etc...
Old Feb 15, 2006 | 09:30 PM
cilvia's Avatar
Default HELP: lights dont come up on heater/ac etc...
i got a 97 civic ex coupe...can someone give me tips on how to fix the lights on the heater/ac etc...the green light comes on when i press one of the buttons but i cant see which one im pressing cause the pictures dont light up anymore....sometimes i gota keep switching the cold/hot switch left to right till the lights turn on but doesnt fully turn on sometimes...
Old Feb 15, 2006 | 09:54 PM
Stoich EG2's Avatar
Default Re: HELP: lights dont come up on heater/ac etc... (cilvia)
check y0 fuses y0. then, check the bulbs
Old Feb 15, 2006 | 11:12 PM
94_HATCH's Avatar
Check fuses before anything. Does you guage cluster light up or is it dark also? I would not pull the climate control out to check the bulbs until im sure its not something else.
Old Feb 16, 2006 | 10:38 AM
cilvia's Avatar
Default Re: HELP: lights dont come up on heater/ac etc... (94_HATCH)
ok maybe pictures will explain it more...well everything lights up BUT the lights inside the red square (picture below) dont...i dont think anythings wrong with the fuse cause 40% of the time the lights do come on...but when it doesnt, i gota move the hot/cold **** left to right untill the lights come on...sometimes it would only light the right half of the red square...could it still be the bulb even though it lights up half the time??
Old Feb 16, 2006 | 10:41 AM
the soL that could's Avatar
take out the cluster and get new light bulbs. they're going out. make sure when you press them in, they sit in place tight. 74 is the lightbulb at autozone. happened to me... until i fixed it. the reason you have to move hot/cold is because the bulbs are loose. mine ended up poping because i kept pushin it back and forth during the night.
Old Feb 16, 2006 | 11:08 AM
cilvia's Avatar
Default Re: (the soL that could)
what if i just tighten the bulb down?? or do i really gota replace it?? and how do you remove the cluster??
Old Feb 16, 2006 | 11:31 AM
Default Re: (cilvia)
i would replace it just in case it is damaged. it's cheap.
i unno how to remove it...never had your car.
Old Feb 16, 2006 | 11:34 AM
cilvia's Avatar
so 74 is not the bulb size?? anyone know the size of the bulbs?? thanks
Old Apr 20, 2006 | 11:10 AM
cilvia's Avatar
anyone know the bulb size for the climate control?? AND for the gauges?? thanks
Old Apr 21, 2006 | 02:02 AM
cilvia's Avatar
bump for ^^
Old Apr 21, 2006 | 04:14 AM
Sleepy_Red_hatch's Avatar
search for a post about DIY amber lighting, im too lazy to do so but yeah, bauley lists the bulb sizes clearly in the first few lines.
Shiner_23
Aug 7, 2020 12:47 PM
JJGL-EF90
Feb 21, 2011 11:37 AM
tapuout
12
May 8, 2006 12:16 PM
95integrags-r
Mar 30, 2006 05:41 PM
Edgemingsr
Aug 18, 2004 11:45 AM
