my ef
Old Feb 15, 2006 | 08:58 PM
callinthe187's Avatar
Default my ef
i bought an ef with a swap in it..it got a 93 ls motor ...the problem is now nothin on the cluster works and my signals dont work wuts wrong and wut do i need to fix this problem..oo an by the way its a 90 civic hatch dx..i would appreciate any help
Old Feb 15, 2006 | 09:00 PM
C1CRX's Avatar
Traffic signal tech
Default Re: my ef (callinthe187)
did u check the fuses lol
Old Feb 15, 2006 | 09:06 PM
Default Re: my ef (lvcrx)
yeah that was the first thing i checked even though its all corroded cause they took the ls fuse box and jamed it in the side but i checked all the fuses..its the cluster that dont work the rpms mile per hour gas nothin works..
Old Feb 15, 2006 | 09:23 PM
flipkc's Avatar
Are they all plugged in properly/securely and in the correct places? Make sure there's no damage to the wiring harness.
Old Feb 15, 2006 | 09:25 PM
Default Re: (flipkc)
ima have my boy chek it for me tomorow well bter sadi today..lol...but my friend said that it might be the harness that i cant use the ls harness is that true...he told me that i might just need to get the crx si harness for it to work is that true also
Old Feb 15, 2006 | 10:58 PM
hondatuner123's Avatar
Default Re: (callinthe187)
lmao, u should just run the ef harness man. way easier with much less hassle .
Old Feb 25, 2006 | 12:25 PM
Default Re: (hondatuner123)
its an ls motor homie
i need an si harness for it to work rpms mph and all that stuff i wasnt talkin bout the lights obviously it has to be the fuses
Old Feb 25, 2006 | 12:31 PM
SD_Lurker's Avatar
HT White Ops
are you a gangster homie?? An e-thug with a motor swap?
Old Feb 25, 2006 | 12:47 PM
rewerbcrx's Avatar
Default Re: my ef (nicks_jdmstyle_ef9)
rywire.com
or hf harness... those guys are good!
JDM_CAM23
Oct 12, 2011 08:39 PM
Lao17
22
May 31, 2010 07:51 PM
ryanevansoh
Oct 5, 2008 05:47 PM
typerkila
Jan 9, 2008 06:07 PM
