civic chamber
I have a 97 Ek 4 dr soon to be lowered on Tein S tech springs. Im just look in to correct the negative chamber on both front and rear, so should i go for the skunk 2 chamber kit up front or a more basic SPC one. Can the rear chamber be corrected without a chamber kit ( by an alignment shop)? ONce again i just want to correct the negative chamber so my tire wear will not be messed up.
1. its camber. not chamber.
2. negative camber is not harmful nor a bad thing.
3. you do not need to reduce the negative camber.
4. bad toe from lowering your car causes bad tire wear, not negative camber.
5. get an alignment to fix your toe. leave the camber alone, it will be out of "spec". doesnt matter.
6. enjoy.
6. enjoy.
Coopa B18c5
Jan 18, 2013 07:58 PM
MikeHock
Mar 27, 2004 10:40 PM
