what clutch do i use?????? please read
Old Feb 15, 2006 | 06:37 PM
highrev1987's Avatar
Default what clutch do i use?????? please read
i have a 1990 civic hatch that i am putting an 1990 Si trans into and my car has a d16z6 swapped into it do i buy the clutch for the 1990 civic or the 92-95 Si/Ex. please help. i know the 92-95 is a hydro clutch but i want to run cable 4 lyfe.
Old Feb 15, 2006 | 06:40 PM
EL Vap133's Avatar
Default Re: what clutch do i use?????? please read (highrev1987)
get the 90 Si clutch.
Old Feb 15, 2006 | 06:43 PM
Default Re: what clutch do i use?????? please read (EL Vap133)
so i always use the trans specific clutch not engine specific?
Blue Hybrid's Avatar
i used the clutch off the 1990. but i remember that the 92-95 pressure plate bolts to the 88-91 flywheel
beyondspexj's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by EL Vap133 &raquo;</TD></TR><TR><TD CLASS="quote">get the 90 Si clutch. </TD></TR></TABLE>
Old Feb 15, 2006 | 06:57 PM
jlicrx's Avatar
Default Re: what clutch do i use?????? please read (gold EF)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by gold EF &raquo;</TD></TR><TR><TD CLASS="quote">i used the clutch off the 1990. but i remember that the 92-95 pressure plate bolts to the 88-91 flywheel</TD></TR></TABLE>
all 90-00 pressure plates will bolt to the 90-91 flywheel (not 88-89, which use a smaller clutch) - when you are buying a clutch kit that comes with throwout bearing, if you have a cable clutch you need 90-91 kit and if you have hydraulic clutch, you need 92-00 kit - throwout bearings are different between cable and hydraulic
thecruzs2007@yahoo.com
Jan 4, 2011 03:29 PM
shadycrx
Jan 7, 2006 11:12 PM
Kyles ej1
Nov 3, 2004 07:02 PM
phatrick2332
May 17, 2004 10:11 PM
vaporboy12
Jan 6, 2004 06:57 PM
