d15b vtec swap help
Old Feb 15, 2006 | 06:03 PM
GhostInTheShell's Avatar
Default d15b vtec swap help
Posting for a friend: He purchased this motor off of ebay a couple weeks ago because his is shot. It will be going into a 95 Civic DX and we need to know the technicalities of this swap. Will the ECU need to be changed? What's going to happen with the wiring? Anything else we should look out for? Thanks for the help
-Dave
Old Feb 15, 2006 | 06:12 PM
BlueIntegraBoy's Avatar
Default Re: d15b vtec swap help (GhostInTheShell)
You need to wire up the VTEC solenoid to your ECU. Use the FAQ thread on the first page to learn how. You will then need to use the P08 ECU that should have come with your swap, if not, use a P28 ECU.
Old Feb 15, 2006 | 06:21 PM
Default Re: d15b vtec swap help (BlueIntegraBoy)
Thanks
Old Feb 17, 2006 | 08:07 AM
TTT for anything addition
Old Feb 17, 2006 | 08:10 AM
the soL that could's Avatar
^^ pretty much said it all. i have this engine in a 94 del sol S. i was already wired for vtec to the shock tower (you might be also) search... p08 ecu #1 if you can find it.
Old Feb 17, 2006 | 09:37 AM
ZCVTEC-SOHC's Avatar
From: PhantomGrayEH2, CA Where Gay Arnold Rules, USA
Most likely your swap is not going to come with a P08 ECU. A P08 ECU would be ideal for a D15b because that is the ECU intended for that engine. But since a P08 is a single wire O2 sensor ECU you would have trouble with your four wire O2 sensor that your DX comes with. What you need to do is either get a P28 and call it a day, or get a P28 and have it programmed to P08 specs while maintaining your DX four wire O2 sensor. Good Luck.
Old Feb 18, 2006 | 10:13 AM
accordianex's Avatar
I just bought a 93SI hatch
the kid put a D15B into it, now i dont know what ECU he put into it.
it seems like its runnng rich,
the O2 sensor that is installed is a 4 wire, he gave me the one wire O2 sensor.
can i just install the one wire O2 and tap into a wire?
how can i find out what ECU i have??
Old Feb 18, 2006 | 01:39 PM
Default Re: (accordianex)
Look at the ECU itself and there should be the ECU code on the side. Don't install the one wire O2 sensor, keep your 4 wire just get a P28.
Old Feb 18, 2006 | 03:06 PM
T-RO's Avatar
OR... you can just chip the DX ECU you already have
cityofcaterpillars
Engine Management and Tuning
Apr 13, 2016 07:06 PM
ddubp71
Aug 22, 2010 11:09 AM
92EGMINIME
20
Mar 6, 2009 07:14 AM
ATK_Tae
Nov 15, 2008 05:32 AM
cramers coupe
May 29, 2005 05:50 PM
