Ride Height on STS/STS2 Civic/CRX?
I need a little help. We're not going to get ANY testing at all on the new CRX before next weekend's divisional, and I'm not going to get a chance to get it up on some scales before then either.
So if anyone is willing to share your ride heights on 88-91 EFs with 205/50/15s I'd greatly appreciate it. You can IM it if you don't want it to be public info, I promise I won't tell.
Going from memory (Civic is at work and CRX is on jackstands) I think we run around 4.5" front and rear. Then just zip tie the shock shafts and make sure you're not running out of travel.
Is that measured from the bottom of the jack tab or from the rocker panel?
I'm guessing jack tab. From the rocker that'd be kind of low.
paulzy
Jun 27, 2002 10:37 AM
