Evap Control Canister vacuum lines.
Old Feb 15, 2006 | 04:21 PM
huntarrr's Avatar
Default Evap Control Canister vacuum lines.
So there are two (2) vacuum lines on the top of the Evap Control Canister. The one closest to the wall goes to the solendoid which is already hooked up on my car. The second vacuum line (which is farthest from the firewall) goes where???
Motor is a y7 block and y8 head.
Modified by vsm98civic at 9:57 PM 2/15/2006
Old Feb 15, 2006 | 05:15 PM
THC07's Avatar
Default Re: Evap Control Canister vacuum lines. (vsm98civic)
need more info, which IM are you useing, the Y8 i hope. which # in you picture are you talkin about.
Old Feb 15, 2006 | 05:35 PM
huntarrr's Avatar
Default Re: Evap Control Canister vacuum lines. (THC1107)
Scratch the connector pipe question. I swapped the old one with the one nipple on the block.
My main question is where does the second vacuum line (farthest from the wall) coming off the Evap Control Canister go? Im using a y8 i/m.
Modified by vsm98civic at 9:45 PM 2/15/2006
Old Feb 15, 2006 | 07:24 PM
huntarrr's Avatar
nevermind.. im an idiot. goes to the fuel rail.
EJ8_Man
Jan 18, 2011 08:55 PM
Maldito X
Jun 16, 2010 05:50 AM
jmccalip
Jun 15, 2008 09:45 PM
b18cEK
20
Jun 21, 2005 10:29 AM
