Are the more expensive cooling fans worth it?
will they give you any gains? I was reading the summitracing catalog and one of the fans for $200 read
"By replacing your stock engine-driven fan with one of these Flex-a-lite Black Magic electric fans, you can get back up to 17 free horsepower that the stock fan was stealing. With a powerful motor and steep blade angle, Black Magic fans can move up to 2,800 cfm of air--enough to cool 300 HP vehicles without air conditioning, and 250 HP vehicles with air. These 15 in. diameter puller-type fans have an adjustable thermostat and a fiberglass shroud that withstands heat up to 250 degrees F."
Is this true or should i stick to a $50 pep boys one?
just get a 12" slim fan for $90 or so. i cant speak for those $200 fans. but if you have a good radiator you shouldn't need an expensive fan. mine hardly even comes on.
edit: your stock honda fan is electrical anyways so there would be no freeing of power anyways.
Modified by Pee Wee at 8:33 PM 2/15/2006
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ludesrv »</TD></TR><TR><TD CLASS="quote">17 horsepower?
How? Buy cooling down the engine to stock heat spec? Oh wait, it does that by itself with stock everything.</TD></TR></TABLE>
thats only implied with vehicles that have belt driven fans
If you are worried about cooling put a AC fan on there and wire it to the current fan then you have plenty of cooling power. Honda fans are already electric therefore you will not free up 17hp.
<---Wonders why anyone would need that much CFM flowing through the radiator.
KINGVEM^^ED6
11
Mar 11, 2012 08:04 AM
