Opinions needed asap:Remote Starter install advice.
Old Feb 15, 2006 | 02:53 PM
nasirjones9mm's Avatar
Default Opinions needed asap:Remote Starter install advice.
I want to install a remote starter from circuitcity.com myself instead of paying the $100 installation fee. Is installing a remote starter hard. Can i find directions and diagrams to help me?
It is for a 5sp 2000 Honda Civic. I already have an alarm and power locks/keyless entry.
Old Feb 15, 2006 | 03:13 PM
B18C_EJ8's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote &raquo;</TD></TR><TR><TD CLASS="quote">Is installing a remote starter hard.</TD></TR></TABLE>
Depends. Are you comfortable taking portions of your car apart? Can you solder?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote &raquo;</TD></TR><TR><TD CLASS="quote">Can i find directions and diagrams to help me?</TD></TR></TABLE>
You can find them at http://www.bulldogsecurity.com
Are you purchasing a remote start designed for a manual transmission car?
Old Feb 16, 2006 | 08:11 AM
anewbreedx008x's Avatar
Default Re: Opinions needed asap:Remote Starter install advice. (nasirjones9mm)
dude i work at circuit city, u get the remote start but on a 2000 civic u need another part called 556UW its a interface for the chip in the key, which u might have considering u got factory alarm and keyless, u better read the manual really well cause u gotta hook up factory alarm arm/disarm go into and u gotta find the lock unlock wires all kinds of crazy ****, bring it to circuit city dude u can screw alot of **** up if u dont kno wut ur doin
Old Feb 16, 2006 | 08:21 AM
suspendedHatch's Avatar
Default Re: Opinions needed asap:Remote Starter install advice. (anewbreedx008x)
I have to agree. If it was just a straightforward alarm then maybe you could figure it out. But doing remote start on a manual you're going to wish you just paid the $100 which is not a lot for the pain in the *** that it is. We get people like you coming back in desperation willing to pay whatever we want to charge them in hopes that they didn't fry their new alarm.
Alarms are especially picky. Twist and tape or bad butt connections just wont cut it. T taps or scotch locks like what BB uses are also very problematic.
I'm not sure if anyone at CC will even want to do remote start on a manual though.
Old Feb 16, 2006 | 02:21 PM
JSPECSIR's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by anewbreedx008x &raquo;</TD></TR><TR><TD CLASS="quote">dude i work at circuit city, u get the remote start but on a 2000 civic u need another part called 556UW its a interface for the chip in the key, which u might have considering u got factory alarm and keyless, u better read the manual really well cause u gotta hook up factory alarm arm/disarm go into and u gotta find the lock unlock wires all kinds of crazy ****, bring it to circuit city dude u can screw alot of **** up if u dont kno wut ur doin</TD></TR></TABLE> since you work at cc I would have thought you would have checked the tech sheet on a 2000 civic before telling him bullshit like he needs a 556u.
DIRECTWIRE™ WIRING INFORMATION - HONDA / CIVIC / 2000 / Remote Start
[PRINT THIS PAGE]
12volts white + ignition harness
Starter black/white + ignition harness or
Notes: In 6 pin white plug behind fuse box
Second Starter
Ignition black/yellow + ignition harness
Second Ignition yellow + ignition harness
Third Ignition
Accessory white/black + ignition harness
Second Accessory
Keysense
Power Lock green/white - keyless entry module
Notes: The keyless entry module is white in color, and located in the drivers kick panel.
Power Unlock green/orange - keyless entry module
Lock Motor white/red drivers kick panel
Unlock Motor blue/red drivers kick panel
Parking Lights+ red/black keyless entry module
Parking Lights-
Hazards
Turn Signal(L)
Turn Signal(R)
Reverse Light
Door Trigger lt. green/red - OEM alarm plug
Notes: The OEM alarm plug is to the right side of the steering column. The plug is green.
Dome Supervision same as doors
Trunk/Hatch Pin blue/black - OEM alarm plug
Hood Pin
Trunk/Hatch Release
Power Sliding Door
Factory Alarm Arm
Factory Alarm Disarm
Disarm No Unlock
Tachometer blue test connector
Notes: Drivers side fire wall under hood in a 2 pin plug
Wait to start
Brake Wire green/white + brake switch
Parking Brake
Horn Trigger gray - OEM alarm plug
Memory Seat 1
Memory Seat 2
Memory Seat 3
Interface Module: Category:
Immobilizer Bypass Required:
No Type:
N/A
Part #: N/A
Notes:
This wiring information is being provided free of charge on an "as is" basis, without any representation or warranty. It is your responsibility to verify any circuit before interfacing with it using a digital multimeter.
Directed electronics, Inc. assumes no responsibility with regards to the accuracy or currency of this information. Proper installation in every case is and remains the responsibility of the installer. DEI assumes no liability or responsibility resulting from improper installation, even in reliance upon this information.
Old Feb 16, 2006 | 04:25 PM
B18C_EJ8's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote &raquo;</TD></TR><TR><TD CLASS="quote">since you work at cc I would have thought you would have checked the tech sheet on a 2000 civic before telling him bullshit like he needs a 556u</TD></TR></TABLE>
LOL.... True dat.... Honda didn't start putting immobilizers on the Civics until the 7th gens came out.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote &raquo;</TD></TR><TR><TD CLASS="quote">T taps or scotch locks like what BB uses are also very problematic.
Although I'm sure they are used, T taps and ScotchLoks are in the list of banned items in BB install bays.. They're not allowed in my bay...
Old Feb 16, 2006 | 08:55 PM
Default Re: (B18C_EJ8)
My bad. T taps and scotch locks are common to independent shops, but BB uses butt connectors. Correct? My statement was too generalized.
Old Feb 17, 2006 | 11:17 AM
fcm's Avatar
fcm
Old Fart
Here is a tag in sheet... http://www.directwholesale.net...eID=3 and as has been mentioned all the connections should be soldered, also you should not need a relay for the "Clutch Interlock Switch" connect the remote starts "Status Output" or ground out when running to the starter relays side of the switch, probably a blue/black wire.
If the alarm system uses a "Starter Cut", motor will not turn over when alarm is triggered, then the starter output from remote start has to be wired in "down stream" of the "Starter Cut" relay.
To find out, trigger alarm and try starting the car, what happens, or I should say what does not happen?
Feel free to IM me if you need more help. 94
matase
Dec 14, 2014 07:02 AM
tekstyle
Audio / Security / Video
Apr 28, 2008 11:51 AM
slowjett
Dec 26, 2006 08:55 PM
nyo91
Mar 19, 2004 05:25 PM
12 oz.
Dec 15, 2003 09:50 AM
