type r rear sway bar on em1 chasis
hi i tried searching but nothing came up, would a type r rear sway bar hook right up too the 00 si chasis or would i need new lca's....
also, i was wondering what else can i do too my suspension, i have front and rear strut braces, st front sway bar, obx rear and front lower tie arms, kyb agx with skunk2 lowering springs. what else can i do to make my car handle better for autocrossing this year. I am looking for a rear sway bar too buy so that will be on as soon as i can find one...
any input would be helpful...
The sway bar will fit, but you need the Si endlinks. In addition you will need a subframe reinforcement like the ASR kit, or the sway bar will rip right out.
wait isn't the EM1 a strut car?
Im sure you could get it to work, but i think it might need to be custom.
PM vtecvoodoo to see if eibach makes anything
well my car is a 00 si....and already comes stock with a 13mm rear sway bar....the reason i'm asking if the itr or ctr rear sway bars will fit is b/c i heard that when you upgrade too sway bars bigger than 19mm you need new lca...but all the forums i read are for cars that are non si's....
any input for those other 99-00 si owners..
they do fit, I went from stock 13mm rear sway bar on my 1.6EL to 22mm CTR...all I added was subframe reinforcement (Beaks kit at the time), now going the much safer route...ASR brace with 23mm JDM ITR rear sway bar.
The end-links will work too if they are not seized, but subframe reonforcement is a must.
You'll need the rear sway bar with bushings and brackets, hardware and subframe reinforcement.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Slow_import »</TD></TR><TR><TD CLASS="quote">well my car is a 00 si....and already comes stock with a 13mm rear sway bar....the reason i'm asking if the itr or ctr rear sway bars will fit is b/c i heard that when you upgrade too sway bars bigger than 19mm you need new lca...but all the forums i read are for cars that are non si's....
any input for those other 99-00 si owners..</TD></TR></TABLE>
No you use your stock lca's...
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by EK4civichatch »</TD></TR><TR><TD CLASS="quote">EM1 is the 99-00 si.
EM2 is the later strut civics..</TD></TR></TABLE>
ok, makes sense
ok, makes sense
it will fit... u just need different d brackets.. you can use the stock em1 endlinks... if u have the si u do not need the new lca's
p1driftfiend
14
Feb 23, 2004 12:18 PM
