Buddy Club Spec 5 cams??????
Old Feb 15, 2006 | 12:03 PM
LSV_REX's Avatar
Default Buddy Club Spec 5 cams??????
Ive heard some good things about buddy club cams, but Im not sure if I can run them in my setup (CTR pistons in an LSVTEC) I do have a .040" headgasket but Im not sure if I should go with a stage 2(spec IV) or stage 3(spec 5) setup.
Modified by LSV_REX at 1:17 PM 2/15/2006
Old Feb 15, 2006 | 01:00 PM
92TypeR's Avatar
FSAE
Default Re: Buddy Club Spec 5 cams?????? (LSV_REX)
https://honda-tech.com/zerothread?id=1523438
You'll find a lot of good info in there.
The problem with the BC5's is that the overlap is sooo big that you have little room for cam adjustment. With OTS CP pistons I had barely over 2 degrees (+/-) maximum before piston to valve contact.
You will be able to tune the BC4's more extensively, and with that compression, make more power compared to the BC5's.
Old Feb 15, 2006 | 04:19 PM
LSV_REX's Avatar
Default Re: Buddy Club Spec 5 cams?????? (92TypeR)
thanks man
94EG2B18
Dec 15, 2011 09:31 PM
NASuperSi
25
Feb 21, 2007 12:05 PM
joethejoeman
Feb 7, 2007 01:42 PM
PearlCrx
Mar 5, 2004 12:51 PM
civiksi
Jun 9, 2002 09:27 AM
