1998 JDM TURBO INTEGRA GSR $13,000 OBO NEGOTIABLE (PHOENIX ARIZONA)
POSTING FOR A FRIEND. ALL QUESTIONS/COMMENTS - PLEASE CALL THE POSTED NUMBER BELOW, DO NOT PM.
$13,000 OBO VERY NEGOTIABLE
Motor work ?
Bottom end has 1560 miles on it:
Arias 9.8:1 factory overbore pistons ?Eagle h beam rods with upgraded arp 3/8 rod bolts ?Golden eagle head studs ?Golden eagle overbore head gasket ?Block overbored to factory spec ?Crank micropolished ?Walls honed ?ACL main bearings ?ACL rod bearings ?ACL thrust waster
2000 Integra type R head with 20,000 miles??Turbo setup ?
Precision/Garrett hybrid turbo-60 trim wheel, to4e compressor cover, 360 center section with Single ball bearing wheel, .63 turbine housing with 5 bolt down pipe flange ?Rev hard ceramic coated cast manifold ?Tial 38mm wastegate with .4 bar spring ?3 inch stainless steel mandrel bent downpipe with 10” flexpipe all tig welded by autowerks ?Rev hard intercooler ?Rev hard intercooler piping-2 inch from turbo to intercooler, 2.5 inch from intercooler to Throttle body ?Turboxs type h blow off valve ?Precision 440cc injectors ?Goodrich oil feed line ??Electronics ??Greddy profec e-01 boost controller?Greddy emanage upgraded to gold?Blitz df2 turbo timer ?Autometer boost??Exterior ?
OEM jdm itr front end conversion with black housing headlights and lip ?Painted sideskirts to match rest of the car ?Type r rear spoiler ?15 inch bronze Rota circuit 8’s with falken azinis ?Red Honda badges ?Shaved rear wiper ??Interior ??Dynamic auto seats ?Skunk 2 short shifter ?Skunk 2 shift **** ?Carbon fiber dash trim ?Greddy e-01 lcd screen ?Jdm type r gauge cluster ?Dynamic racing pedals ?Carbon fiber ebrake handle ?Type r shift boot ?Leather ebrake boot ?Type r arm rest ?Honda seat belt pads ??Suspension/Brakes ??2000 Type R front brake calipers ?Ground control coil overs ?Tokico illumina shocks ?Type r rear trunk brake ?Custom lower rear strut bar ?Jdm type r rear sway bar with bsq endlink kit ???Transmission ??Replaced with brand new oem unit total of 20,000 miles on it now ?Act 7lb flywheel ?Act extreme pressure plate with organic disk ??Other ??Autowerks custom 3/4 core radiator ?Ngk spark plug wires ?Mugen oil cap ?3 inch stainless steel manderal bent catback exhaust with magnaflow muffler ?Energy suspension motor mounts
DEI Python alarm system (not installed)
NOTE:
THESE ARE ALSO NEW ITEMS WITH ABOUT 2,000 MILES ON THEM:
BATTERY
STARTER
ALTERNATOR
HOSES
BELTS
TO DATE:
Engine (bottomend) has aprox. 3-4,000 miles on it
Engine (head) has aprox. 25,000 miles on it
Transmission has aprox. 25,000 miles on it
PLEASE CONTACT ANDY FOR INFO AT:
HYPERLINK "mailto:ACEBOARDR@YAHOO.COM" ACEBOARDR@YAHOO.COM
602-614-4226
Motor work ?
NOTE:
BATTERY
STARTER
ALTERNATOR
HOSES
BELTS
TO DATE:
602-614-4226
HickamHatch
Dec 10, 2008 05:21 PM
11SECEG
Northern California (Sales)
Jul 13, 2006 11:32 PM
