Question: Civic Type R Steering Wheel SRS Install
Old Feb 15, 2006 | 08:09 AM
jdmxGod's Avatar
Default blah
kl
Modified by jdmxGod at 10:08 PM 2/15/2006
Old Feb 15, 2006 | 08:27 AM
jdmxGod's Avatar
Default Re: Question: Civic Type R Steering Wheel SRS Install (jdmxGod)
anyone?
Old Feb 15, 2006 | 09:42 AM
NineTwoSi's Avatar
If it is truly a CTR wheel then it is a direct fit... If it's a ITR wheel (which looks exactly the same) it's not.
Old Feb 15, 2006 | 04:07 PM
Suzukablue's Avatar
yeah it will fit but be ready to reset your SRS because the light will surely be on. at least thats what happened to me.
Old Feb 15, 2006 | 04:12 PM
ExCon's Avatar
Default Re: Question: Civic Type R Steering Wheel SRS Install (1cleanEJ8)
Im pretty sure that they arent identical!
Civic Type R
Integra Type R
Old Feb 15, 2006 | 04:41 PM
jdmxGod's Avatar
Default Re: Question: Civic Type R Steering Wheel SRS Install (JDMedEK)
acutally it is identical, because the picture you have of the intergra type r steering wheel is a 96spec NON-SRS Steering wheel, the integra 98spec SRS type r steering wheel looks identical.
Old Feb 15, 2006 | 05:48 PM
NineTwoSi's Avatar
Yes and no... In your comparison they are different, but that is the non-srs itr wheel... The SRS wheel is identical to the CTR wheel.
Old Feb 15, 2006 | 06:36 PM
professor poon's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jdmxGod &raquo;</TD></TR><TR><TD CLASS="quote">Hey guys, i was wondering if the Civic Type R Steering wheel SRS from japan will fit any Civic 96-00 USDM Hub? is it a direct fit or do i have to buy something else to make it fit. let me know. Thanks</TD></TR></TABLE>
Let me know if you can get one for any less than $350 and where...those things are pricey!
Old Feb 15, 2006 | 06:49 PM
fishnfst's Avatar
IF your not as concerned with the bling factor a s2000 wheel and an insight steering wheel are also direct bolt up...
Old Feb 15, 2006 | 06:55 PM
Redline96LX's Avatar
* B A N N E D *
Default Re: (fishnfst)
Yeah the Insight wheel looks pretty cool
Old Feb 15, 2006 | 06:57 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by fishnfst &raquo;</TD></TR><TR><TD CLASS="quote">IF your not as concerned with the bling factor a s2000 wheel and an insight steering wheel are also direct bolt up... </TD></TR></TABLE>
I kinda like those...looks like the only diff is the silver honda emblem instead of the red one
Old Feb 15, 2006 | 07:13 PM
NineTwoSi's Avatar
EK's get all the pimp *** direct fit steering wheels. EG's get screwed...
Old Feb 17, 2006 | 08:04 AM
ExCon's Avatar
Default Re: (NineTwoSi)
&lt;--learns something new everday!
INTEGRA TYPE R ^^
CIVIC TYPE R ^^
Old Feb 17, 2006 | 07:59 PM
Heretic:Si's Avatar
dc5 itr wheel bolts right up too
Old Feb 17, 2006 | 08:10 PM
R-Lug's Avatar
Default Re: (Heretic:Si)
^^ no it doesn't
Old Feb 17, 2006 | 08:31 PM
Heretic:Si's Avatar
Default Re: (SeaLevel)
if a ctr wheel fits so does the dc5, its also confirmed since ive had both
Old Feb 17, 2006 | 11:25 PM
supapoopa's Avatar
Does the airbag also work when swapping over?
Old Feb 18, 2006 | 06:24 AM
NineTwoSi's Avatar
Default Re: (supapoopa)
If you wire it up right... I put an EDM ITR wheel in my EG and had to repin the airbag and now it's all good!
Old Feb 18, 2006 | 02:19 PM
R-Lug's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Heretic:Si &raquo;</TD></TR><TR><TD CLASS="quote">if a ctr wheel fits so does the dc5, its also confirmed since ive had both</TD></TR></TABLE>
Oh Dc5, thought you said Dc2
Old Feb 21, 2006 | 11:56 AM
Heretic:Si's Avatar
for both of mine (ctr, dc<U>5</U> itr) they plugged right in
PR8urVtec
May 1, 2015 01:08 PM
OAHU808GROWN
Aug 19, 2009 10:39 PM
Nextelbuddy
Jun 12, 2003 12:04 PM
